Should a Fan Clutch Bearing Have Any Play/Wobble?
Old 05-13-2010, 07:26 PM
drspencer
drspencer's Avatar
Default Should a Fan Clutch Bearing Have Any Play/Wobble?
'71 350/270.
When grabbing the outside edges my fan blades, I can make the fan clutch wobble a little bit on the shaft. Is this acceptable, or should it be replaced?
Sub Question: Where should I buy a new fan clutch? Aftermarket? Repro? does it even matter?
Old 05-13-2010, 07:29 PM
JimT
JimT's Avatar
There should be no wobble.
You can pick one up from Summit for a reasonable price. Check out their web site.
Old 05-13-2010, 08:22 PM
mikejpss
mikejpss's Avatar
Location: Where it's always hot as Hell-South Louisiana.
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
no wobble .
since these are probly used on many gm vehicles during that period, personally would use one from a general parts house.imho.
Old 05-13-2010, 08:30 PM
...Roger...
...Roger...'s Avatar
How much is a little bit ?
GM # 88961768 is the best clutch I know of.
Old 05-13-2010, 08:33 PM
drspencer
drspencer's Avatar
Enough where you can 'feel' the slight wobble. If you look close, you can 'see' the play.
Is any amount of play unacceptable?
Old 05-13-2010, 08:37 PM
drspencer
drspencer's Avatar
Is this part # specific to a Corvette?
I have a '71, which I think has some funny irregularities regarding the water pump shaft size.
Thanks again.
Old 05-13-2010, 08:58 PM
...Roger...
Not much is acceptable. The new GM clutches have no play but some of the aftermarket clutches have some play almost out of the box. I hate to condemn every one so if the play is slight I rev slowly and watch the fan blade to be sure the blade is steady going up and down in rpm.
Old 05-13-2010, 09:03 PM
...Roger...
Thanks again.
No it came on other GM models. It was considered a HD or severe duty clutch.
Here is a link to one that has the thickness of the 88961768 but from the number I can't tell if its a GM clutch. I bought my last from my local Chevy dealer.
http://ecklers.com/product.asp?pf_id=23046&dept_id=1249
edit-if your bored check this thread out from a long time ago,lots of talk about this clutch,the original part number is in there to if you want to use it for a search.
http://forums.corvetteforum.com/c3-t...an-clutch.html
Old 05-13-2010, 09:11 PM
drspencer
drspencer's Avatar
Thanks once again, Roger!
To Should a Fan Clutch Bearing Have Any Play/Wobble?
Quick Reply: Should a Fan Clutch Bearing Have Any Play/Wobble?
