Newbie here....
Newbie here....
My son and I just purchased an 81 in decent shape. Needs paint and interior work, but is solid underneath and most electricals work fine. Starts and drives fine.
My question is this: at 190 HP stock, its a bit gutless. What is the least expensive way to uncork this engine a bit?
It will need exhaust soon. Suggestions? Are headers worth the money?
Thanks for any and all input!
Chip,
Upstate NY
Chip,
Upstate NY
Low miles
I forgot to mention that it only has 37k miles on it. The exhaust I'm replacing is original. What about the smog and detuning done in '81 - is there a good guide to follow for removing/upgrading that?
What are your thoughts on headers? Worth the extra time/effort/leaks?
Thanks.
Thanks.
Thanks.
Thanks.
All that smog stuff can come off.... drops about 100 lbs off the car too.
If you have the money get some good heads or just start building a motor on a stand now.
Thanks.
Thanks.
1. Added a 2.5 inch true dual exhaust with 18 inch Chambered exhaust resonators. (sounds awesome!) The cat was already gone when I bought it.
2.Long Tube Headers
3. replaced the Carb with a slightly used Qjet from a 79 L82
4. replaced the dist with a new HEI unit.
5. added a B&M lockup controller for the tranny
6. tuned it per Lars Grimsrud's papers(including dist recurve and settings)
7. (actually first) removed all of the smog stuff, pump, EGR, even swapped the water neck(thermostat housing) for a chrome one that has no places for sensor plugs.
8. Added a ton of chrome, new bowtie valve covers and K&N 14 inch open filter. etc...
9. unplugged the computer
Now for the good news, it is night and day better, it is unbeleivable how these are detuned from the factory, it really woke it up. I also picked up a ton of MPG on top of the HP. That may have been from the improperly working computer, that is now gone.
But the grand total, I paid 100 for the headers, 40 for the carb, 35 for the dist. 159 for the Lockup controller, and 50 for the air cleaner. I think the EGR block off plate was 15. The rest is just cosmetic. Be careful about the emission requirements for your area, some require the smog crap to be in place, need not be working, but must be in place, so keep it so if you ever sell, someoneone could add it back on.
Also beware of removing the cat. Lots of states are starting to require cats on cars that came with them. So, at best, get a high flow, rather than just getting rid of it all together.
As for me, best bang for buck "mod" you can do is recurve the distributer. They cost about 10 bucks, and it's a difference you can feel.
Thanks for all the great input.....
Thanks to all for mod suggestions, especially for the low cost ones, as we're starting out with limited funds. We brought it home last night. Looking forward to cleaning it up, removing the smog crap, dueling the exhaust and upgrading the distributor.
Thanks again! Great website - I'll be in here daily watching for more tips.
Spoiler
