Stock 80' flexplate tooth count
Can anyone tell me the tooth count for a stock 1980 Corvette flexplate? My 8th or 9th or maybe 10th starter has started grinding and im getting ready to make my last attempt to fix the block, bolt on a starter, replace the flexplate, and shim it properly and I want it to work this time.
Im checking flexplates online and they have both 168 and 153 tooth flexplates and im wondering what stock would be or if theres a recommended one to use with a stock starter.
EDIT: Oh also Overall Diameter too if anyone knows that since thats also variable at online vendors
If the GM Delco Remy starter has a staggered bolt pattern it mates to a 168 tooth; if the bolts are inline, it mates to a 153 tooth. Exception: if it's an aftermarket gear reduction starter and has 4 bolt holes in line, it can mate to either - if it's shifted inward, it's a 153 tooth flywheel or flexplate; outward it's a 168 tooth.
Diameters are ~12 7/8" for the 153 tooth and ~14" for the 168 tooth.
Thank you both for the responses. Today was another one of those days where I hate owning my car lol. Hopefully I can get everything together and weld some metal on the block somehow and try and get this issue resolved. I wasnt sure if it was a starter/flexplate issue or the block so im just knocking both of them out at the same time.
Then again I may just buy a junk motor and go with that till I break something. But ill try to keep it stock for now.
Weld the block? What's going on? If there are starter problems, were the correct starter bolts used, which have the crosshatching at the end of the threads? These are necessary to prevent the starter from shifting around which is possible with regular bolts. Also were any shims necessary for correct clearance/backlash?
Im narrowing it down to the block piece thats chipped off. Its a decent sized chunk and you can see thread. I thought about putting a threaded bolt up in there with no end on it and covering it with JB weld and covering up the missing piece as well and then putting a nut on the end, also talked about welding some metal somehow on the block and redrilling and rethreading the hole, and finally possibly putting a heli-coil insert in and covering the chip up with JB weld again. None of the ideas appeal to me but im really running out of options at this point. Im hoping to do the starter and flexplate at the same time so it all gets fixed. If it keeps slipping and grinidng im setting my car on fire.
Its going to be a while before I start on her again since my Big Twin oil change is $318... Harleys are more expensive than Vettes
There's a huge force on those starter bolts during cranking, and if they're only screwing into a broken starter boss there will be problems regardless of starter and pressure plate newness. I hope you find a reasonable solution.
