69 vette vacuum system - CorvetteForum - Chevrolet Corvette Forum Discussion
Register FAQ Search Today's Posts Mark Forums Read Vendor Directory
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette
Old 07-09-2010, 11:22 PM   #1
Scholle
Junior Member
Default 69 vette vacuum system
Hi
I bought last year in Sept. a 69 Vette with a 350 engine. Because the wiper door is not working, I recently started looking into the problem and as I checked the all hoses for right connection, I saw that I have just one vacuum relay for both head lights. All vacuum diagrams I saw till today show two relays, one for each head light. Can somebody tell me if that is normal? I mean it looks normal, since there would be no space for a second one. Even my vacuum tank has just two hose connections, a second head light vacuum relay would require a third hose connection at the vacuum tank.
Thanks for any advice.
Markus
Scholle is offline   Reply With Quote
Old 07-09-2010, 11:55 PM   #2
...Roger...
CF Senior Member
...Roger...'s Avatar
The early 69s had just the one relay, much simpler.
EDIT- correction - all 69s had 1 relay ,in 70 they went to 2 relays
...Roger... is offline   Reply With Quote
Old 07-10-2010, 08:00 AM   #3
Scholle
Junior Member
Thanks, that helps me a lot. I have a vacuum plan of 70 Corvette, I assume I can still use this to check the hose connections and the color codings for the wiper system, right?
Markus
Old 07-10-2010, 09:14 AM   #4
...Roger...
CF Senior Member
Quote:
Markus
Go to the Willcox site for many tech drawings.
Here is a link to all the years of vacuum diagrams , click on "supporting documentation" and roll down to early and late 69s. What is your build date or last 5 numbers of your vin ?
http://willcoxcorvette.com/repairand...lp.php?hID=280
Old 07-10-2010, 09:51 AM   #5
Alan 71
CF Senior Member
Alan 71's Avatar
Hi Markus,
In addition to the info Roger passed along I'd suggest that you consider buying the 'Trouble Shooting Guide' that Dr. Rebuild sells. It allows you to understand and TEST each component in the headlight and wiper systems. You do need to have a vacuum pump with gauge (like a Mity-Vac) to do the tests.
It's good to know what's working and what isn't. Many people just begin replacing components and hoses until they finally replace the bad part. This gets expensive quickly and is unnecessary. For example if you cut 1/3" to 1/2" off each end of a hose you have a hose with new sealing surfaces for no cost. Hoses are almost always long enough to do this.
Good Luck!
Regards,
Alan
Alan 71 is online now   Reply With Quote
Old 07-10-2010, 01:11 PM   #6
Scholle
Junior Member
Thanks Roger and Alan,
The last 5 digits of my VIN are 07927, but when I look at your vacuum diagrams I think I have a early one, because my wiper relay is on RH inner fender and it looks like thats the only difference between early and late 69.
I thought about buying a trouble shouting guide, is the Dr. Rebuild the best or can I also order one e.g. from Ecklers, are they all the same? The same with a vac pump, is one frome a catalog enough?
Markus
Old 07-10-2010, 02:43 PM   #7
Alan 71
CF Senior Member
Alan 71's Avatar
Hi M,
According to the NCRS info I'm looking at your 7927 car could very well have the wiper relay on the inner fender, Since it's a Nov. 68 build.
The trouble shooting guide that Dr. R sells is quite a bit diferent than the other guides I ve seen for sale and free on the net. ( Dr. R is a bit DIFFERENT too!)
I'd think any vacuum pump with a gauge will help you out.
Regards,
Alan
Old 07-17-2010, 10:24 PM   #8
Scholle
Junior Member
Thanks Alan,
I got my trouble shooting guid from Dr. R and a vacuum pump. Today I started searching for failure parts and I found out that both relays are not tight anymore and much worse, it looks like my vacuum tank is leaking as well. I have that big square one with two hose connectors sitting on the LH inner fender and I'm not sure if I have to disassamble the brake cylinder to get the vacuum tank out. Did anybody disassamble a vacuum tank on a early 69 vette and can give me some tips how to do that?
Old 07-17-2010, 10:55 PM   #9
Willcox Corvette
Premium Supporting Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Willcox Corvette's Avatar
Scholle-
I'm not sure you can rebuild them, I've brazed up cracks in them before but I've never tried to take one apart.
Willcox Corvette is offline   Reply With Quote
Old 07-17-2010, 11:19 PM   #10
Scholle
Junior Member
My first question would be how to get the tank off the vehicle. It looks like I have to get the brake cylinder out of the way first.
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • 69 vette vacuum system
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    Headlight relay hissing billschroeder5842 C3 Tech/Performance 8 08-20-2016 12:23 PM
    How Your Headlight Vacuum System Works 78IndyPace C3 Tech/Performance 195 05-01-2016 06:45 AM
    69 Vacuum Tank Location Horejsi C3 General 17 09-18-2014 10:42 PM
    Headlight on 1977 won't go up or down Joe 77 C3 Tech/Performance 6 05-06-2004 08:42 PM
    headlight vacuum problem found, still have a ? jonny4523 C3 Tech/Performance 9 06-20-2003 01:57 PM
    Tags
    69, corvette, diagram, dr, problems, rebuild, system, sytem, vacume, vacuum, vette
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
