Bee Jay's RPM Air Gap Mod
If it ain't broke, fix it. Earlier this year while I was looking for all of my lost low end torque and trying to figure out why I was getting terrible vacuum readings, a few of you suggested that eliminating the gap in the plenum divider would add a ton of torque and 100s of inches of vacuum. The problem was at the time was the timing gear being off a tooth. Easy fix. Vacuum and compression went up. But, my friend Gill and I decided to test the manifold gap theory. He built an aluminum gap filler and drilled and tapped screw holes and mounted and glued it in. I'm letting the epoxy and locktite dry overnight and will start and drive the car tomorow and see if it made a difference.
Bee Jay
Bee Jay
One of the chevy magazines (Super Chevy or Chevy HP)tested about 30 s/b manifolds last year, the rpm airgap is an easy winner, even besting super victors and other high end single planes up to about 6500, on a mild and a built motor.
I already head the Dart airgap, which I thought was the same until I read this article, you have the right manifold, right out of the box!!! Wish I had one. Good luck with the fix.
Bee Jay
Carb Spacer?
BJ: Any chance of testing a carb spacer? I don't have any dyno time planned any time soon. A spacer is on my list of things I want to try.
Your plenum mod was also on the list! LOL
Thanks for keeping us posted.
R
R
1 Post
Cruise-In VIII Veteran
I'll be interested in seeing how the butt dyno reads.
What you have done is defeating the purpose of the cut down divider and effectively changed what makes the Air Gap such a good manifold, one of the best out there.
The cut down divider is to allow this dual plane manifold high RPM performance while still allowing low end power too.
I doubt you will notice any difference unless you do a back to back chassis dyno session with and without your spacer insert. What you will find is approximately the same low end torque but you will lose some HP around 6000RPM and above with the insert in the manifold.
I did a back to back test between the Air Gap (dual plane ) and a Vic Jr( single plane ) and found the low end torque and HP to be pretty much the same until around 6000RPM where the Vic jr pulled a couple more HP out of the motor.
I would have used the RPM Air Gap ( I did for a year or so ) but I switched to Vic Jr when I found out contrary to popular belief the single plane didn't "lose" any TQ compared to the dual plane Air Gap and I like the looks of the Vic Jr better. So it really came down which manifold I liked the looks of better because this motor was only really capable of about 6000RPM so the performance of one or the other didn't really matter.
Now my new 427ci small block is capable of ~8000RPM and the Vic Jr was the only manifold I would put on
So these are the results of 2 specific manifolds and may or may not hold true for any other dual or single plane manifolds.
Engine Size?
MH: Would the increased displacement of your engine be a reason the AG and the Vic jr are so close? All those cubes need extra cfm, the Vic jr does flow more. Most tests on 350 SB show a Vic jr is a little much for the smaller milder SB. A 427 @ 8K will need mucho cfm! LOL
R
R
Corey, the bolts are almost an inch long. No way for them to come out with the carb in place.
Motorhead, my engine is only 350 cubic inches. It wants to grow up and be just like yours some day. I've read in several places that cutting down the center divider adds high rpm horsepower but lessens low end torque somewhat. I just wanted to try it and see. Easily removeable, so no harm, no foul. I just got back from church. The wife is putting dinner on. Then I'll get out of my 1st Sunday monkey suit and put on my speed racer suit. Details at 11.
Bee Jay
Bee Jay
