1968 Right mirror install
Well I got a really nice set of reproduction GM licensed mirrors. On the 68 the mirrors are only about 3 inches back from the front of the door.69-79 they are back about 10 or so inches.The right side is mounted with rubber swell nuts.My only concern is on my 68 is there enough room behind the door panel that far forward for everything to clear inside.This car is painted and completed. I don't need a surprise after I drill the door.I will tape it up start with a small drill and go to the size it fits tight in. HAS ANYONE DONE THIS ON AN EARLY 1968, mine is one of the 1st 1500 thanks.
You need to decide if it's more important to have the mirror in the 'correct' placement...as it came from the factory....OR if you want to see what is behind you when driving. The early '68 mirror placement was not the best for "safety" purposes. Plus, if you are going to put a right-side mirror on your car [the factory did NOT install these...only installed by the dealer and is not considered 'correct' by NCRS], placing it similarly to the early '68 location will render it totally useless.
If you are going to drive the car regularly, put the mirror in the '69-'76 location and take a minor 'hit' on the NCRS points (also for the right-side mirror).
Note: In my opinion, NCRS is doing a great disservice to the driving Corvette community by deducting points for the right-side mirror. They should share some concern about owner safety and allow the right-side mirror with no deduction in points.
Received 1,468 Likes
Cruise-In II Veteran
Hi
Posted already in your other thread. I have left + right mirrors in the 68 early fwd position.
Plenty of space behind the panel for the well nuts.
Just as a note. Only early 68 have the mirrors in the fwd position.
Late 68 versions as of about February build date have them further back same as later C3s.
Rgds. Günther
Correct, specially when this where dealer options , hence semi correct.
Rgds. Günther
Just to put things in perspective, the deduction for a right side mirror is 1 or 2 points out of 4500. The deduction for a burnt out dash lamp is 25 points...........
Save the 2 point deduction for those that move the early 68 mirrors to the safer location.
-W
The NCRS mirror deduction is assessed no matter where it's mounted.
