77 A/C pressure switch
on the A/C pressure switch under the right front fender, there is a tan wire in and a green wire out to the compressor. My green wire is broken at the plug. How do you fix that? can i get a new plug?
I would go shopping at the wrecking yard if it were me. Most of those earlier GM cars will use the same connector for the pressure switch and compressor connector.
