Which way should I run the electric choke wire?
Hello, I am having a little issue with trying to run this electric choke wire without it looking out of place! I thought about getting another breaded hose (smallest I can find) and running it in the hose. Any ideas? Thank you all
You can run the wire as you have it but cover it with convoluted tubing. I my wire through the firewall and to an accessory recepticle on the fuse panel. I have a 79 which uses the blade type fuse though. I'm assuming you are going to splice in to the windshield wiper motor wiring?
It's kind of hard to see in this photo, but that's the whole point. I used black wire and ran it along the rubber tube for the choke vacuum (my card doesn't supply choke vacuum) and along the vacuum line for the distributor can. I used the smallest black zip ties I could find to keep them all together. I ran the wire through the firewall to the IGN term on the fuse block and put a 10A fuse in the line.
Pete
Pete
If you have an idle solenoid (brown wire), you can tap off of that and wrap around the carb base out of view. I can't see if you have one in the pic with your air cleaner on.
How about the windshield washer yellow wire -- will it also work? My car is apart and can't try. The washer sits on the wiper motor and has a yellow and blue wire. Easier to tap into!
Here is a better photo showing how I ran my choke wire. Using a black wire will help hide it if that is your goal.
I might get flamed for this, but tapping the power from the wiper motor circuit sounds like a Bubba trick to me. There is a power tab on the fuse box made for tapping power. Use the IGN tap for your choke. You need a female spade connector and an inline fuse, 10A, ought to do it. Label the wire at the fuse box as electric choke and no future owner or person working on the electrical system will be confused.
Pete
Pete
Nice engine Pete!
Agree the black wire is stealthier than the red -- but since black is universaly accepted as a ground, and we don't want to incite the flamers, I'll add a red tape band at both ends and every 12 inches on the wire!
Thanks for the idea!
Pete
Pete
Primoz (05-01-2017)
