68' 427 belt routing
Old 09-24-2010, 09:11 AM
damageinc2785
Cruising
damageinc2785's Avatar
Default 68' 427 belt routing
i need the belt routing and belt part #'s if anyone has this
i can't find pictures or info anywhere
its a 1968 427/4 speed with p/s only
no air pump no a/c
thanks
frankie
Old 09-24-2010, 11:12 AM
Jeff_Keryk
Jeff_Keryk's Avatar
The belt makes a triangle around crank, water pump and power steering pullys. Any decent auto parts store should be able to look the belt up.
Old 09-24-2010, 12:54 PM
TimAT
TimAT's Avatar
My 69 uses this setup:
Belts:
Dayco 15325 Crank to Water pump
Dayco 15445 Crank to water pump to Power Steering
NAPA 25-08003 Power Steering to Alternator
The critical one is the Crank to Water pump- too long it slips, too short it eats water pump bearings. And remember this is a 69 427/435 belt setup
Old 09-24-2010, 02:47 PM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,468 Likes on 1,247 Posts
Cruise-In II Veteran
There is a dagram in the assembly instruction manual (AIM) showing the correct belt routing and original GM belt part numbers for all '68 engines and options combinations.
Old 09-24-2010, 03:18 PM
damageinc2785
Cruising
can you scan it? or give me a link to it?
Old 09-24-2010, 03:33 PM
PRNDL
PRNDL's Avatar
Top sheet/picture is 327 engine belt configurations, bottom sheet is for bigblocks.
The circled setup is from my AIM, because that is what I have - p/s, no a/c. My AIR pump is gone so I don't have that belt. Note there is a redundant belt from the waterpump to the crank. I don't have that one either, I just have 2 belts.
Old 09-24-2010, 04:55 PM
thatcorvetteguy
thatcorvetteguy's Avatar
Good luck with the GM belts you'll need it. I tried useing them and they just don't fit between the crank and water pump pullies.
Old 09-24-2010, 08:05 PM
Ironcross
Ironcross's Avatar
Most local parts stores will be normally selling either Gates, Dayco, or Goodyear belts....all major brands and there catalogues are all correct as to lengths and widths in the OE configurations....If your system has been altered then my suggestion is to visit the locals and have them measure the old ones with their belt gauges.....
To 68' 427 belt routing
Quick Reply: 68' 427 belt routing
