Hood support fupport cracking..... help in fiberglass repair needed.....
Today I realized my hood support bolt attaching location was breaking, pretty amused but what can I do.
Anyone had this problem?? any suggestion to fix it???
Also anyone with pictures of the insulation on the hood, how is it attached???
Anything missing here????
Man that's a bummer. I had the same thing happen to me on a road trip from Rhode Island to Georgia. You need to have it professionally repaired. It needs to be someone familiar with Corvettes and Corvette/fiberglass body work. Mine gave out on me in Charlotte, NC and I was lucky enough to find a guy named Dub who owns Corvettes Etc. He charged me $250 and the job was done well. It took 5 days to get the hood back on the car because Dub informed me that the resin that he used to repair the crack had to cure. He said that was key for the longevity of the repair. I trusted him and what he said. The repair is still going strong 2 years later with many opening and closings of the hood. So the proof is in the work. Good luck.
yep, that one sucks... my 72's hood has the same problem and when I posted about it some time ago someone said it was most likely from where the fiberglass had fatigued and then when the hood was open and the latch wasn't released someone tried to close the hood and it fractured the mounting point there on the hood. I was told it had to be cut open from the top of the hood and go in through the backside. I have yet to fix this problem and am all ears and listening here for other suggestions...
sully
sully
Received 2,878 Likes
Hi s,
It looks like the nut plate rivets are gone and have allowed the plate to move. Can you see if the plate is still there?
Regards,
Alan
Regards,
Alan
my hood was broke at the hinge when i bought it .i is not a hard fix.it was my first time working with glass.i used a dremel to cut the glass.you can buy a kit for $10.00 .the hard part is getting the metal brace that the bolts go into in the right place .now is a good time to think about getting something cool on the inside of your hood .you have to do some paint work anyway.i want a set of cross-flags.
Vette Shop Near Dublin VA?
Hey guys and gals, rekindling this thread due to my 73’ is beginning to have this issue. Is there anything I can do to keep it from getting worse or a temporary fix? If not does anyone have a shop in the southwest part of VA they know does good glass work, or vette shop (specifically Dublin ,VA)?
BG
BG
Reviving a long dead thread.
My hood broke today too... under structure broke and came loose from the top surface
where the prop mechanism connects.
Too much pressure on old dry fiberglass I guess... anybody have a fix short of a new hood?
mardyn
mardyn
DUB
I'll try and post up some photos of the damage asap... I've been pretty busy around here with other stuff the last few days.
My initial thought is to remove the hood, rebond the inner and outer structure back together
with some kind of panel adhesive, reinforce the under structure and then fab up and external brace to better distribute the load over a longer/wider area...
Oh yeah. I'm gonna do all this without damaging the paint on the top side of the hood.. but will have to repaint the repair area on the under side.
I've been quite agitated about how it was actually damaged (by a tech who was recharging the A/C), but it was really an accident and not much to do at this point but man up and fix it.
I'll try and get some pics up tomorrow
mardyn
mardyn
The hood obviously has to come off. So the outer skin can be bonded to the inner structure.
As for the crack in the inner structure....it will need to prepped and laminated on to try to get it strong again. Do this as soon as you can so it does not get any worse....so when you lift the hood the inner structure does not crack further. The last thing you want is the inner structure to crack all the way and separate.
DUB
DUB
DUB
DUB
