problem with gm zz427
Old 11-12-2010, 09:52 PM
Ben Lurkin
Ben Lurkin's Avatar
St. Jude Donor '09
Originally Posted by ZZ71S
Good luck with that!!!
Well, it certainly won't work if you don't pursue it.
Old 11-12-2010, 11:58 PM
mvette76
mvette76's Avatar
dad is still going to deal with gm, we have all winter to come up with a plan. it is embarrassing to start his car with all the smoke it makes at start up and with the side pipes it get everyones attention!
Old 11-13-2010, 01:39 AM
eagle275
Support Corvetteforum!
eagle275's Avatar
On problem now is, it's govnment motors. Might be like dealing with Social Security, Medicare, or the IRS.
Old 11-13-2010, 02:55 AM
elle88
elle88's Avatar
i googled " zz502 problem " and in the Chevelle forum there are at least 3 threads about various issues with the GMPP BB crates.
Aside of the oil consumption issue (low tension rings, no plate hone) , there are also bolt-nuts randomly not torqued, random cylinder bores not honed, piston rings upside-down... all kind of things forgotten while making the engine. Are they drinking beer while making the engine?
Scary !!!!
I was almost there to buy a ZZ454... good that I read these things in time
Old 11-17-2010, 11:23 AM
mvette76
mvette76's Avatar
my old man has been talking to gm this week and it sounds like they are going to make it right! we will know more later this week but it sounds like they will pay for him to take it to the shop of his choice to perform the repairs!but we still have to pull it! ugh!
Old 11-17-2010, 11:29 AM
brando1118
brando1118's Avatar
Hey that's great news!
Imagine working to pull the motor all along knowing that you would have to fit the bill of the machine shop yourself. At least you know that your work will be justified and worth it! I would find the best machine shop in a reasonable area. You will end up with a much better in motor in the long run. Congrats and good luck!
Old 11-17-2010, 12:01 PM
larryg3
larryg3's Avatar
good to hear that GM will make good.
Good luck!!!
Old 11-17-2010, 09:16 PM
Duane4238
Duane4238's Avatar
I'm 60 years old and have spent my whole life in Tonawanda, New York, home of the Tonawanda engine plant. I know they don't make the crate engines, but I know (knew) many guys who've worked at the engine plant on the line, and the majority of them don't even know how to change a spark plug and could care less about how the pieces go into an engine. Only concern is how much they make an hour. I'm sure it's the same at the crate motor plant. If buying a replacement engine, go with a reputable machine shop's recommendation and do your research first!
Duane
Old 11-18-2010, 04:55 PM
mvette76
mvette76's Avatar
Well it is official gm called my dad back and they are paying for a rebuild of a shop of our choice!
Old 11-21-2010, 03:34 PM
mvette76
mvette76's Avatar
got the motor out today! off to the the machine shop tomorrow!
Old 12-22-2010, 07:53 PM
mvette76
mvette76's Avatar
the motor is back together with new pistons and rings.today it was run on the dyno and broke in then we made a few pulls it made 489hp 480torque
Old 12-22-2010, 11:55 PM
Ben Lurkin
Ben Lurkin's Avatar
St. Jude Donor '09
Very good news & nice #'s! So much for the naysayers. Did the shop offer any insight regarding the oil issue?
Old 12-23-2010, 07:20 AM
  #33
mvette76
mvette76's Avatar
they did not find any tell tale signs but his theory is bore was a little to big and pistons where to small causing the piston to rock causing the rings not to seal. i don't have all the tech numbers in front of me right now but could get them if wanted. gm sent a rep to look over every thing at the shop too.
Old 12-23-2010, 10:38 AM
  #34
ajrothm
ajrothm's Avatar
Received 1,095 Likes on 746 Posts
Congrats! Nice numbers.....did you guys change anything else in the engine to boost power or just a basic bore/hone/piston job?
Basically you guys did what GM should have done in the first place and bored the freakin cylinders right, then honed them with a torque plate. Sloppy sloppy work on GMs part and this is a fairly common occurrance on their crate motors..... I won't ever buy one.... or atleast not a new one....maybe an old used 502 and rebuild it myself using local machinists so I can over see the work.
Old 12-23-2010, 04:23 PM
  #35
mvette76
mvette76's Avatar
everything is out of the crate except pistons and rings! i tried to talk him into a little more cam but he said no
Old 12-23-2010, 04:39 PM
  #36
ajrothm
ajrothm's Avatar
Considering GM only rates them at 430hp, I would say the piston swap gained a good bit of power..... Plus they are probably a little under rated from GM to start with.
It has the same cam/heads/intake as the ZZ502 only less 75 cubic inches....yet yours is making within 12hp of the 502 so.....pretty damn good I'd say.....
Quick Reply: problem with gm zz427
