Coil Wiring
Coil Wiring
The wiring diagram I have for a 71 Corvette shows the resistor wire (yellow) that runs from the starter and the hot wire from the key are both connected to the negative coil terminal. I thought that both these wires should be connected to the coil's positive terminal. Which is right?
Thanks in advance.
Thanks in advance.
Funny, I have three wiring diagrams showing the the hot wire from the key and the wire going to the starter are both being connected to the negative coil terminal. However, I do have a link to a fourth wiring diagram that shows those wires going to the positive terminal.
Rodger, thanks for confirming that the three wiring diagrams are wrong. Also, I do know the key wire goes to the resistor. Guess I had a brain fart when I wrote it was the other wire.
Thanks.
Thanks.
