How Your Headlight Vacuum System Works
Old 12-08-2010, 10:59 PM
Peterbuilt
Peterbuilt's Avatar
Received 1,244 Likes on 965 Posts
Originally Posted by marcmullins
ok my headlights wont go down. if i remove one of the yellow stripe hoses from the tank and put my finger over the tank port the opposite headlight goes down. then do the other and they are both down. when lights are switched on they both come up very slowly. what could be my problem? thanks oh its a 1978.
Test the actuators here: http://www.corvette-101.com/vacuum.htm#actuator
Then test thr relays here: http://www.corvette-101.com/vacuum.htm#relay
redkenyan (01-28-2018)
Old 12-08-2010, 11:22 PM
marcmullins
2nd Gear
marcmullins's Avatar
Originally Posted by petes74ttop
thank you.
Old 12-09-2010, 08:24 PM
Roadking
Support Corvetteforum!
Roadking's Avatar
Thanks for taking the time and posting this. Next on my todo list.
Nice workup.
Old 12-09-2010, 09:06 PM
snoopykissedlucy
snoopykissedlucy's Avatar
I've posted it before but:
I used my shop vac instead of hand-pumping a mity vac. Works like a charm to pop-up the lights and pop them down(my motor was out of the car at the time)
Redbirdman (05-19-2019)
Old 12-09-2010, 09:39 PM
CaseyJones
CaseyJones's Avatar
St. Jude Donor '15-'16
FINALLY! A comprehensive write-up with diagrams that make sense!
Old 12-10-2010, 12:13 PM
69 Chevy
69 Chevy's Avatar
Another vote for making this a sticky.
Old 12-10-2010, 12:56 PM
CA-Legal-Vette
CA-Legal-Vette's Avatar
Thant's 6 votes by my count.
Old 12-10-2010, 05:03 PM
Will's'74VetteL-82
Will's'74VetteL-82's Avatar
Thanks for the great information, and yes, this should be a sticky!
Will
Old 12-11-2010, 12:17 PM
78IndyPace
78IndyPace's Avatar
Default Update to .pdf File
Thanks again, all, for your kind comments and support.
I intend to maintain the .pdf file that is linked-to in the original post of this thread with updates, corrections, comments, and good stuff from posts on this thread and elsewhere. Click on that link and you'll always get the latest version.
Today's update adds vacuum reservoir tank test methods and tank locations description (from Mid America Motorworks), and a link to Willcox Corvette's “Headlamp Vacuum Hose Schematics 68-82”.
Jerry
78IndyPace
Old 12-11-2010, 05:52 PM
H P Bushrod
Moderator
H P Bushrod's Avatar
CI 5-6-7-8-9-10-11-12 Veteran
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18-'19-'20-'21-'22-'23
Stuck! Very informative. Thanks for sharing the info!
Old 12-12-2010, 09:38 AM
Mike Ward
Mike Ward's Avatar
Originally Posted by H P Bushrod
Stuck!
Thank you!
Old 12-12-2010, 11:34 AM
...Roger...
...Roger...'s Avatar
Originally Posted by Mike Ward
Thank you!
This should help.
Old 12-12-2010, 06:07 PM
  #33
JunkdriverToo
4th Gear
JunkdriverToo's Avatar
Default C3 headlights
A big Thanks to all. After understanding how the system works, we located the problem (the lack of vacuum) to the headlight pods. Troy is very happy with his vette.
Old 12-16-2010, 08:48 PM
  #34
Rockn-Roll
Rockn-Roll's Avatar
Very well done.
Old 12-26-2010, 09:51 PM
  #35
kirt8548
kirt8548's Avatar
I've just recently replaced all of the vacuum hoses. Now the lights go up and stay up. If I disconnect the hose that goes to the tank, they won't go up.
Anyone have any thoughts?
Old 12-27-2010, 09:34 AM
  #36
78IndyPace
78IndyPace's Avatar
Given your brief problem description, my guess is your hose connections on your relays are reversed OR the hose connections on your actuators are reversed. Check your connections against Figure 4 in the original posting. When you find and correct your problem, please post your fix on this thread.
Good Luck!
Jerry
Last edited by 78IndyPace; 12-27-2010 at 09:48 AM. Reason: Added question by kirt8548 in quote.
Old 12-29-2010, 08:05 PM
  #37
80Baby
80Baby's Avatar
Jerry, this is an excellent post. I recently completed the restoration of both of my pop-up headlight assemblies. I studied the mechanical linkages of the originals before I ripped apart and rebuilt them. But when it comes time to re-install them, plus run all of the vacuum lines - knowing how the system works will ensure that everything goes back together properly. You've done much to guarantee that this will happen. Many thanks.
To How Your Headlight Vacuum System Works
Old 12-30-2010, 11:56 AM
  #38
martinsw
martinsw's Avatar
Jerry - Kudos for the great information and glad to see it is now a sticky.
I do have one suggestion - the title of the post should be
"How your headlight vacuum system is supposed to work".
I even put in a vacuum gage in place of my clock so I know when (not if) something is amiss in the vacuum system.
Old 01-05-2011, 11:35 AM
  #39
hgoodwiniii
hgoodwiniii's Avatar
Awesome posts. On to-do list.
Old 01-06-2011, 04:32 PM
  #40
tristan69
tristan69's Avatar
Default Great post thanks so much
Jerry, I recently replaced all my vacuum lines and my headlights work great and so does the wiper door.....that is until about 5-10 minutes later the wiper door will raise. WTF
I have my car in the shop for re-painting but want to fix this as soon as it comes out. I was going to clamp of the vacuum supply to the wiper door and see if I can hold the door down. If this works I would move the clamp further from the door until I find the leak.
Do you think this will work or do you suggest a better method.
All the best and once again thanks.
Quick Reply: How Your Headlight Vacuum System Works
