Tilt and Telescopic Column Rebuild Video
Old 12-23-2010, 12:17 AM
snoopykissedlucy
snoopykissedlucy's Avatar
Default Tilt and Telescopic Column Rebuild Video
I wasn't sure if you guys have already seen this series of videos on youtube. (there are three videos and the fourth is missing)
The guy isnt a mechanic but has rebuilt several chevy columns and looks 80% competent. I have rebuilt a C3 T/T column and it is very similar to this.
PS-the special tool mentioned doesnt need to be bought- you can use a bolt and socket arrangement instead.
http://www.youtube.com/watch?v=Nq4zN...eature=related
Old 12-23-2010, 12:28 AM
snoopykissedlucy
Here's the bolt and socket setup I used to get the pivot pins pulled off.
(its a 1976 T/T steering column)
Old 12-23-2010, 12:37 AM
snoopykissedlucy
Here's another guy doing a Chevy T/T loose column repair.
I wish I had seen these the first time I did my repair!
http://www.youtube.com/watch?v=RFP5O...eature=related
Old 12-23-2010, 04:44 PM
JohnRR
JohnRR's Avatar
Great info, I'm going to save the links.
Old 05-18-2014, 11:29 PM
easyshooter
5th Gear
easyshooter's Avatar
Here is my problem...I bought the fancy lock down clamp but my telescoptic shaft just pulls all the way out when I try and reinstall the c-clip??? Now what?! Dam!
Old 05-23-2014, 07:43 PM
sjarrett71
sjarrett71's Avatar
I just used a smaller pan head screw to put down the hole. When I screwed my lock plate tool down it put pressure on the screw which put pressure on the shaft which is down the hole which locks the column in place.
Old 05-23-2014, 09:22 PM
'75
'75's Avatar
This is the one I use, the bolt screws into the shaft and locks the telescope, easy as pie!
Old 05-24-2014, 07:32 AM
Jim Shea
Support Corvetteforum!
Jim Shea's Avatar
Otherwise, go out and purchase a 5/16 - 18 UNC set screw or a #20 Allen screw. Install the screw so that it locks and upper steering shaft and prevents it from telescoping while you use the special tool to compress the steering column locking plate. Just remember to remove the screw when you are done or your telescope feature will be permanently locked.
Jim
To Tilt and Telescopic Column Rebuild Video
Quick Reply: Tilt and Telescopic Column Rebuild Video
