Muncie Experts PLEASE Help! Trans blowing gear oil out of everywhere
My muncie trans has gone crazy. It is blowing gear oil out of all the seals and the front when running. It acts like it is pressurizing some how. I have never seen anything like it. Neither have any of my mechanics. To my knowledge there is no real vent on a muncie. Just a hole at the bottom of the front bearing retainer. What could cause this?
Drain it and fill it with GM syncromesh or equivalent so the oil just starts to come out the fill hole. If it still leaks you probably need to rebuild it. The case could be worn in the area where the counter gear shaft is located (front) thus leaking. Good luck.
It is not a gear oil issue. The gear oil was never touched or changed. Simply pulled the trans and put it back in as I replaced the shortblock. Same gear oil as before. But you run the engine about 5 minutes and the oil starts pouring out the front of the trans. Swapped it for another unit I have that is freshly rebuilt. DID THE SAME THING. What could be causing this. As the only thing that changed was the engine block could the input shaft be binding to one side or something so that the front bearing retainer is not pushing the oil back as is should. Have talked to at least 5 mechanics and NONE have a clue and have never seen this happen.
It is not engine oil, this bellhousing has a removable cover plate on the bottom. You can stand there and shine it up on the trans input shaft and bearing retainer and watch it come pouring out. The pan and rear main are dry as a bone. Not to mention I know what gear oil smells like and its viscosity compared to engine oil. After you run it 5 minutes the trans is half empty. It is the trans, period.
Location: Where it's always hot as Hell-South Louisiana.
1 Post
St. Jude Donor '07-'08-'09-'10-'11-'12-'13
In ANY case, I am hoping you will post the answer to this riddle when you find it. Good luck.
found this on another site which may pertain to the second rebuilt transmission
My bet is that the retaining nut is installed backwards... About 25 % of the muncies i take apart that were rebuilt before have the nut on backwards.... The nut is actually a oil slinger arrangement that is designed to vent the transmission and keep the oil from running out the bearing retainer...
This might be a dumb question, but have you installed the drive shaft and speedometer cable? If not, then that's where it's coming from. Gear oil will get slung onto the top of the tranny and then run down to the back and out the tail shaft through the speedometer cable hole or output shaft.
Will ask my mechanic friend tomorrow...he will know if anyone in America knows what is wrong...he has shelves that have muncie parts and gears that are piled 4 ft high and they are at least 25 ft long...he has built more/fixed more muncies than chevy has. He was the corvette specialist for years before moving to his own shop at his house. The dealership begged him to let them bring the troubled cars that no one else could fix to his house...he declined as he had a hell of a reputation all over this town and everyone wanted him to fix their cars...me included...the book calls for 8 hours to pull a vette rear end (68) or so...it takes him 45 min with a friend helping.
We were just talking yesterday about venting auto trans and engines and rear ends....
Jimmy in NC
Jimmy in NC
Since you have the same issue with 2 different tranny's, it MUST be in the motor. You mentioned a new short block. IMHO, your problem lies there as you also mentioned (above). Occam's Razor rule applies here in my opinion. If you look hard enough, your answer will be in the new short block- rear main bearings,etc....unless of course, your newly rebuilt tranns was not properly rebuilt .. are you convinced it was done correctly also?
I have also tried venting the trans through various means including taking out the side plug and putting in a piece of fuel line to let it vent. MADE NO DIFFERENCE.
Very strange. So, awhile back you were having problems with your 496 but seemed to have it figured out if I remember correctly. My question probably has nothing to do with your current situation but I'm curious anyway- did you end up replacing that 496 for some reason?
