Pilot Bearing vs Pilot Bushing
I have a C3 with a 350 Muncie 4sp and am in the process of changing the clutch. In the process I figured I'd remove the pilot bushing and change it as well (I was afraid that Mr Murphy and his law would rear it's head and the bushing would fail right after I reinstalled the transmission).
I've read on a number of forums very mixed comments on using the original pilot bushing vs switching to a pilot bearing. Any ideas which is better/safer and what the best source is for the bushing? (I have a Centerforce pilot bushing on hand)
Also what is the best way to install either?
Jim
Jim
I am no expert on this, but from what I have been told and from what I have seen on other forums including the Chevelle and Camaro forums, bearings can break. Bushings are pretty much bullet proof.
I am also no expert on this as well but I will have to agree with jaychis. The bearing is better in some retrospecs. It will handle better than a bushing if you are doing intown commuting in heavy stop and go traffic. The downside to the bearing is that it has no external lubrication after installation and no cooling function installed what so ever for the bearing itself. When it fails it will be a complete seize up unlike the bushing. I also look at it like this, the factory bushing lasted for how long? I imagine a new one will last just as long as the last one. Either way I think you will be satisfied with which ever you choose. Preventative maintenance always helps tho.
Oil-lite bronze to be exact just like they used back in the day. The market is now flooded with cheap Chinese pilot bushings made of material with iron in it, if a magnet sticks to your pilot bushing you will have a high pitched squeel sometime down the road.
Autogear has had so many problems that they took it upon themselves to make a line of pilot bushing made of the correct material. Here is the link: http://autogear.net/WhatsNew1.html
Bronze/oil lite bushings are porous and will hold grease; a cheap steel bushing will eventually damage the input shaft of your transmission.
Hi
The way I understood it is that a bushing does not demand 100 % lign up of the transmission shaft, hence takes some sideload without complaining.
A nearing needs 100 % lignup and the bellhousing must be centered ( trued ) for this, but will then be superior to the bushing.
New cars have bearings.
I installed a GM bearing when I installed the GM Viper T56.
Rgds. Günther
Rgds. Günther
I have been running a bearing on my Muncie then TKO and now T56. All have used the same bearing with no issues. If it is lined up correctly and installed correctly either one will work well.
I'm sure if a bearing is installed correct and if you use a high quality bearing such as kevlar, it should last as well as a bushing. My concern and several stories I have heard, when the bearing goes it could take the tranny input shaft with it if not caught right away.
I think the best way to install it is with a bushing installer tool..if you get the right type of porous bushing..soak it for a day before installing..its a habit of mine that I do..never had a solid bushing die on me yet..I have a bunch of these bushing install tools as I use them when I rebuild a trans..I think mine are old S&K set..
TKO 5-600 calls for bearing, you have to dial in the input shaft to .005" if I remember correctly
