front crossmember dimensions
Are there any existing dimensions of the front crossmembers of the C3 and mainly with regards to the suspension pickup points. I can't seem to find any on the frame charts that go around.
Try the phone number in this pdf. for the year you need. I have seen on other sites that these guys will fax it to you.
http://www.klinesauto.com/PDFs/Curre...%20Library.pdf
Its a frame specification listing most likely used by autobody shops.
