Speedo repair
Speedo repair
My speedometer does not work but the odometer is working fine. I replaced cable and nylon gear already. Looks like I have to yank the speedo out and have it fixed or replaced. Has anyone had to have there's overhauled? Can it be done with a kit or do you have to send it out? Thx - 69 conv 350/300 4 spd.
Re: Speedo repair (Surfer69)
Thats weird...usually the speedo works but not the odometer. If the odometer works that means the three gears within the speedo are good so the problem lies within speedo needle drum assembly. Sounds like either the shaft that drives the drum is broken or needle shaft is fused.
I repaired mine myself recently (odo wasn't working) because I was unable to locate any repair facility or a complete rebuilt unit (discontinued). Some people have had to either buy a new speedo (housing, lens & all) or have located working used ones (Contemporary Corvettes has them ocassionally).
Mark
Mark
While they were doing mine the did the needle seats also. this is tricky and unless you know what your doing I wouldn't attempt it. Removing the speedo is a PITA from what I hear.
I would recommend removing it and having it rebuilt...
As I just found out make sure you re lube the cable before reinstalling the speedo. Mine was bouncy after I got the car back and I had to pull the cable after. In fact I just did it an hour ago.
:flag
I have seen the work this guy does on speedos. I think he also sells higher rated speedos for everybody who wants theirs to say more than 85mph.
Website is: http://www.clockdoc.net
Bill Russell
Clock Doc corp 1-800-256-5362 (toll free)
clockdoc@blomand.net
Bill Russell
Call John Devorski at Red Line Gauge & Clock Repair (1-800-375-2310) - a fellow Forum member told me about them when my speedo was going out and they were one of the best vendors I have ever used. They can send you a speedo before you take yours out so you will never be without or they can fix (or convert) yours if you prefer. By far the cheapest and quickest of all the companies I considered. My '81s speedo was going out and I wanted a 140 mph unit. When it was all said and done it cost me $58 and I didn't have to wait while I sent my in and then for them to send me one back. They deserve my high praise.
Thanks dshrack, called John up and he's sending a rebuild for $72 ready to go.
Just have to send back mine once I have received. Good choice.
