Head Bolt Question
Head Bolt Question
Is using standard motor oil under the head of the bolt acceptable? Or, do I need ARP assembly lubricant?
I do have the ARP sealant for the threads.
Do2g,
You need to use a sealant on all the head bolts so coolant doesn't creep up the threads and start to leak. I think some forum members had issues with the ARP sealant. Search for head bolt leaking coolant. You will find some hits on the subject.
Good luck.
Good luck.
If the torque spec calls for "wet" torque, I believe the place for that lube is on the threads themselves. A thread sealer would suffice, and I can't imagine that the drag of the bolt head against the head or thrust washer would influence final torque by much. I am prepared to get educated though!
I would think any type of lube under the head of the bolt to obtain a accurate torque reading would be adequate. I use just a dab of assembly lube and smear it around the shoulder of the bolt and the washer when applicable.If I read your question accurately.
You didn't specify where the bolt is being installed.
Received 1,875 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Motor oil is fine if you use stock TQ specs. ARP sealant will do well too. Or GM or any of the other thread sealants.
Be careful using ARP lube though because it is slippier than regular oil and you will need to adjust TQ specs so you don't stretch fasteners. It's best used with their fasteners along with the specs for that lube.
JIM
JIM
