Anyone have a Keisler RS 500/600?
Old 07-29-2011, 01:20 PM
  #41
KeislerSales
KeislerSales's Avatar
Originally Posted by JD ZR1
I have a 67 L79 350 hp with 3:70 rear gear. Any ideas on using the new RS trans 400 vs 500..non racing just cruising.
Based on your info the RS400 will be all you need. The only difference between the two is the input shaft and spline count.
RS400= 1-1/16" Ford style 10 spline input shaft
RS500= 1-1/8" GM "fine" 26 spline input shaft
The 500's input shaft is stronger allowing for the added 100 lb-ft torque capacity.
KeislerSales is offline
Old 07-29-2011, 02:10 PM
  #42
qwank
qwank's Avatar
wouldn't the RS600's gear ratios be a better fit with his rear end ratio though?
qwank is offline
Old 07-29-2011, 02:28 PM
  #43
KeislerSales
With a big block it would for sure but with a lower torque 327 I prefer the lower gear to get the engine up on it's legs so to speak. Realistically, at 5000 rpms there's only a 5-7 mph gap between the 3.37 and 2.80 first gear.
Old 07-29-2011, 02:32 PM
  #44
qwank
qwank's Avatar
makes sense.
I'm going to be going with the RS500, as my rear gears are 2.87
qwank is offline
Old 07-29-2011, 02:38 PM
  #45
JD ZR1
JD ZR1's Avatar
Default L79 and keisler 400 vs 500
Keislerjeff , thanks for the response. I had a tremec 600 with a ls2 engine in a 67 restomod i made .it was great, this car is a matching number but i love driving it. I was wondering about the launch with the 3:70 reargear and the different gearing between the 400 and the 500 close ratio 1st and second gears. Should my launch wi th the 3:70 and the 400's 3.37 be rapid, smooth and not need to slip , or should i buy the 500 with the 2:80 ratio?
JD ZR1 is offline
Old 07-29-2011, 02:45 PM
  #46
KeislerSales
makes sense.
Old 07-29-2011, 02:54 PM
  #47
JD ZR1
JD ZR1's Avatar
Default 400 vs 500
I will order a 400 today...thanks
JD ZR1 is offline
Old 07-29-2011, 03:26 PM
  #48
KeislerSales
Great! The phones are busy and I have a guy out so hang in there if you can't get me. Thanks!
Old 07-31-2011, 11:36 PM
  #49
bryanpl123
bryanpl123's Avatar
Keisler,
As was asked earlier, I'm also curious how you arrive at the stated torque limits for each. What does your test consist of? Would an engine that occasionaly flashes to 435TQ kill the RS400? Also, if one wants to upgrade from the 400 to a 500 due to engine upgrades what would it take, just the different shaft? Would you sell this to customers?
Thanks,
Bryan
bryanpl123 is offline
Old 08-01-2011, 10:36 AM
  #50
KeislerSales
Originally Posted by bryanpl123
Keisler,
Thanks,
Bryan
The test is a continuous duty cycle of 24 hours at the stated torque rating. The RS400 for example, sees 400 lb ft for 24 hours straight. A flash of 435 or even 485 would not hurt the trans.
I refer guys to this video on youtube quite frequently. This guy is running the original stock T45 in his car. Check it out!
http://www.youtube.com/watch?v=MfGKMUb1GCA
Old 08-01-2011, 11:47 AM
  #51
bryanpl123
bryanpl123's Avatar
Thanks for the reply and the link!
Old 06-24-2012, 10:17 AM
  #52
bowtie racing
bowtie racing's Avatar
I had to wait my RS600 about an year. And i must say i hated it, and i am sure it came thru via my emails to Keisler. But i have to admit at folks at Keisler handle it really well. I got fast and prompt answers to all my emails. Customer service was really good.
I have no idea to this day is it possible to install under the car with engine on but i could not do it. Not wiht hoist or on the floor. So i took the engine out.
There was one flaw on the main case. The mounting holes for the bellhousing side were about 1/8" offset. So when i mate the transmission and bellhousing ( new from keisler ) i could not install the bolts. I had to grind the mounting tab holes to get the holes in line with the bellhousing.
Driving quality was improved about 1000 times better compared my orginal 3 speed... wich was no suprise. But still beats every munchie, dough nash 5speed or ZF6 wich i have had during the years. Allmost as good as T56 wich i had in my 63.
And the fifth, what a pleasure to drive with 3.7 gear i have
bowtie racing is offline
Old 11-16-2013, 06:16 PM
  #53
Dins74
Dins74's Avatar
Default Just Verifying
Very good thread guys. This looks to be a great forum
I just wanted to verify what I've read. I have a 454 HO crate engine ready to install in a 1974. It has the stock 3.36 rear. Kiesler recommended the TKO 600 is that the consensus here or he RS 600.
Also if the engine is out is removing the cross member a must.
Dins74 is offline
Old 11-17-2013, 01:13 PM
  #54
Priya
Priya's Avatar
I'm not sure they're still making the RS600. It had some hard to manufacture pieces unique to it and they were having a hard time keeping up with demand.
Priya is offline
Old 11-18-2013, 12:37 AM
  #55
Dins74
Dins74's Avatar
OK that would settle that. The response from Keisler was that with the 3.36 rear end ratio the 5th gear in TKO 600 would provide the best performance and that is what I am gathering from this thread.
Thanks for the input
Dins74 is offline
Old 11-18-2013, 12:27 PM
  #56
CheezMoe
CheezMoe's Avatar
St. Jude Donor '11-'12-'13,'19-'20
I have TKO 600 with .64 5th and 3.73.....5th is a very tall gear imo. If I had 3.36 I would go with the .82 5th. Food for thought!
CheezMoe is offline
Old 11-18-2013, 01:04 PM
  #57
Priya
Priya's Avatar
If your car originally had a manual transmission the cross member is non-removable, if automatic than the crossmember is removable. It is my understanding that to remove the transmission with the cross member in place one must unbolt the motor mounts and move the engine forward an inch or two to get clearance to get the trans out. If your motor is already out I think you should be able to get the trans out without removing the cross member. There are also flanges available to convert your non-removeable cross member into a removeable cross member.
http://forums.corvetteforum.com/c3-g...ossmember.html
You might also consider getting the Keisler SS700 transmission which I think is generally regarded as being a better transmission than the TKO.
http://www.keislerauto.com/ss700.html
Priya is offline
To Anyone have a Keisler RS 500/600?
Old 11-19-2013, 02:46 AM
  #58
Dins74
Dins74's Avatar
That's what I was hoping to hear I pulled the engine and Trans together. And figured while it's out now would be the time to get a new Trans. To install are removeable cross member i would have to tow it to a shop for the welding
I researched the SS 700 and that may be too beefy for my driving needs
Dins74 is offline
Old 01-16-2014, 12:37 AM
  #59
AJ123
AJ123's Avatar
I have the tko 600. Had problem with it shipped it back and they were fast and did a great job.
My vet is in the archive files incredible millage. Picture on Pismo beach . the Doug Nash was a junk transmission.T his transmission was an easy install
http://archive.constantcontact.com/f...799060164.html
AJ123 is offline
Old 01-16-2014, 12:51 AM
  #60
bebezote
bebezote's Avatar
Originally Posted by Keisler Automotive
Hi Folks,
The RS400/500/600 models are in production now, and will be shipping in the coming weeks. The RS are NO CUTTING in ALL CORVETTE.
The predecessor to the RS is T45RS, which we have been selling since 2007. In a C3 4-speed equipped car, the T45RS required extending the shifter hole to the right about an inch. This is NOT required for the RS. The RS uses our new PerfectFit design parts for a not cutting, perfect fit, correct driveline angle install.
There are people running the T45RS600 on Pro-Touring.com. Go on there and look at the threads on it, and you can ask them questions.
Alan Covin, the editor of the former Corvette Fever magazine, did a full feature on the T45RS500 in 2009. And you can see his driving video at www.keislertv.com. He was very impressed with the transmission, and liked the shift quality much better than the TKO.
Ok..i want the RS600.... with the tall 5th gear... what is estimated delivery date? Pricing?
sent for from your site... please get in touch...i'll take one
bebezote is offline
Quick Reply: Anyone have a Keisler RS 500/600?
