computer removal on an 81
For those of you that removed the computer harness on an 81. Did it effect the netural safety switch and i read here that you need to install an AC on Switch. Anyone care to elaborate on this?
Dave
Dave
The computer is out, and so is the harness that was on the engine, the harness that was in the cabin is still there. The netural safety switch is on the shifter, I'm not sure what AC on switch your talking about. The AC comes on from the heater control, the computer had nothing to do with the AC.
i pulled my computer out years ago and never touched anything to do with ac or a neutral safety switch (not sure what a safety switch is so someone fill me in about this ). everything ran fine.
if your talking about this blue connection here that i circled , which by the way was the only wire in the harness that split from the ccc harness than i dont think it has anything to do with AC as mine worked fine after the mod.
The neutral safty switch and ac where not affected upon removal of the ccc and harness. If you still have the th350c lockup trany you will lose the lock up funtion. The computer supplies the ground for the tcc lock up once the temp sensor reaches its set point. I removed the computer system and related components 2 years ago. No problems other than the lock up. I ran the car without the lock up until transmission failure but I dont think the faiure was due to tcc not being hooked up. 14000 mi on what apears to be orginal trans with hard driving on my part....she just let go one day. 2004r installed now.
But did you take the harness out too? BTW is that a right hand steer car?
I removed the computer module (next to battery) in mine but left the wiring harness. Need to get it removed. Way to many plugs hanging out of the firewall now.
GB Man77 is from the Land down under. Yes, right side drive. Seen a few Vettes like that there and in the UK. Although his girls Camaro is a left hand driver. That is a nice car also.
There are two plugs on the firewall you can disconnect to pull all that stuff that used to go on the engine. It'll clean things up quite a bit if you haven't already done it. BTW, I hear the weather sucks around there lately...our Corp. offices are closed today...again!
the harness that you can see on the floor comes out in one big slug so i see no reason to remove it at all and block the hole in the firewall.
Rob,
To the OP, I think my neutral safety switch is bad, I am unable to start the car in neutral, but I have seen and talked to many that can. So I know something is wrong.
Yes , 3rd winter storm in about a weeks times or so. Back up in the 60's this wknd though, and just in time for the monthly car show.
