ride height
ride height
Does someone have the ride height for a 1970 Corvette coupe, small block 4spd. I just changed a rear spring, and would like to get the ride height correct. Thanks all.
Here you go.
You need to move the car around and bounce the suspension to assure it is settled into place before taking measurements. Z & D heights are the most accurate, as they pretty much aren't affected by non-OEM tire sizes.
TSW
TSW
Also,
NCRS site has some excellent info in technical discussion.
If it is not an original spring I hope it is by EATON. Those are the only two to get you to the proper ride height from what I have read.. Even EATON can require that you send it back to get recurved.
I also can say that the factory ride height was with a full tank of gas. That is how he factory did it.
Bill
Bill
