Removed Edlebrock Manifold & installed Stock intake, Now lifters Noisy?????
I swapped the Edlebrock with my stock intake manifold. Know my lifters started making a rapping noisy “ Hydraulic lifters” I have never heard that noise before I made the swap. It started with 1-lifter making the noise and it seems that it spread to all the other lifters. I bought new intake bolts (1-1/4’ X 3/8) and torque everything to spec. I also changed the oil after setting up the carb. Does anything go smooth with these C3’s any suggestions?
Re: Removed Edlebrock Manifold & installed Stock intake, Now lifters Noisy????? (73-454)
The only thing that goes smoothly is putting gas in them, a lot. sounds like you have not correctly adjusted the lifters. I thought your cam is a solid lifter. Recheck the lifters and adjust accordingly would be my first guess.
Why did you change the intake?
Re: Removed Edlebrock Manifold & installed Stock intake, Now lifters Noisy????? (69 N.O.X. RATT)
Reason I changed the intake I am re-installing my stock hood, I noticed a bit more low to midrange torque with the stock manifold compared to the Edlebrock Performer 2.0 manifold.
I have a performer manifold and my "hydro" lifters are noisy. More so than some solid cams around town.
This is my first post and may sound a little dum but do you have oil presure .maybe dist is not engaged with the oil pump
8th Gear
You said you changed your oil too. I did that once and I think it was 10W40 like the old days with an old engine and the lifters just wouldn't stop clacking. I changed it right back the same day to 5W30 Pennzoil.
I just adjusted the lifters this weekend per the factory but only 1/2 turn more after resistance felt and now I have 10W30 Mobil1 and it sounds like a sewing machine.
Good luck. :)
Good luck. :)
8th Gear
I read up on oil filters ("corvettefaq.com"), do you have a standard Fram filter installed. They will supposedly cause noisey lifters because of the low filter surface.
I use the double guard right now but I may change filter types after reading their "engine oil filter study".
:yesnod:
:yesnod:
Ya, You should just go ahead and pull that P.O.S. 454 because you have had nothing but problems with it. Replace it with a reliable 383 small block!!!!!!!!!!!!! :yesnod: You must have to much power anyway. Your continuing to remove performance parts.
I think you need to find a shop that knows how to fix things also. Not the shop that you have been so proud of in a few posts. :seeya
St. Jude Donor '08-'09
Could it be that when you re-installed you distributor, that you have your timing too high? Could it be valve clatter instead of the lifters ticking?
Re: Removed Edlebrock Manifold & installed Stock intake, Now lifters Noisy????? (Lt1er)
That's a good suggetion however when you go SB to BB or BB to SB the brackets for everything are all wrong. Unless yo can pick u[p a complete 383 SB it will be a major PITA.
