How to open hood
Old 03-24-2011, 01:06 PM
Vetteman75
Cruising
Vetteman75's Avatar
Default How to open hood
I have a 75 Vette and only the passenger side will pop, anyone have any idea how to get the hood open and how to adjust it?
Old 03-24-2011, 02:21 PM
RonR80
RonR80's Avatar
St. Jude Donor '09
If the passenger side is open you should be able to lift it enough to move the linkage, if not the is a small rubber plug that you can reach behind the firewall in front of the driver side, search this site it's on here,Ron
Old 03-24-2011, 03:18 PM
Colin Paris
Cruising
Colin Paris's Avatar
there is a tool that you push through the plug ( I think ecklers do it?) but i found a piece of 12mm reinforcing rod bent into a curve did the job
Its a bit fiddly and I found that although I could activate the lever to release the hood it still would not lift
I resorted to cutting a spanner (believe 7/16" ) and driving into the end of an aluminium tent pole making a 4'.0" spanner and from the passenger side loosened the drivers side hood stop which allowed it to open Phew!!!
Old 03-24-2011, 06:25 PM
69Trips
4th Gear
69Trips's Avatar
This link may be helpful in visualizing the fix:
http://www.youtube.com/watch?v=Z4BhkZ26nTQ
JR
Old 03-26-2011, 09:09 AM
Vetteman75
Cruising
Vetteman75's Avatar
Thanks for all the info, however still cant get it. I pulled the cable under the hood, and everything else and still drivers side wont pop!!!
Old 03-28-2011, 07:50 AM
RonR80
RonR80's Avatar
St. Jude Donor '09
I have opened them going through the side "gill" just take it off and use a long pry bar , look at the cable and you will see the way to move the mechanism. Ron
To How to open hood
Quick Reply: How to open hood
