Do I Have Gymkhana Suspension
I have a 77 without the manufacturer order. How can I tell by looking under the rear end if I have Gymkhana Suspension or not?
Thanks, Bob
:cheers:
Thanks, Bob
:cheers:
Re: Do I Have Gymkhana Suspension (carlislewax)
Don't make changes to the rear without balancing that with the approprate changes to the front. The gymkhana has stiffer front springs and a thicker front sway bar. Without these your suspension will be unbalanced. Could find your rear trying to pass the front. If you make any changes be sure to look at what changes must be made on the other end.
tom...
tom...
Re: Do I Have Gymkhana Suspension (Tom73)
Wow, never would have thought of that. I'll check it out, before doing. This will be something done down the road.
Check to see if it has a rear bar.
dont the Fe7 cars have a stiff suspension? where as stock was a cruiser... didnt the fe7 have 550 coils?
You want a balanced setup, add the larger FE-7 front bar w/ the rear bar.
Later you could increase spring rates Ft. & Rear.
ZD
Yes & yes.
ZD
Yes & yes.
