Headers and AC bracket...
Another question.....
I got the headers/mufflers/xpipe/gaskets but I noticed my AC bracket mounts on the ram horn, so do I need a special bracket for the new headers or will it be ok with out that one support?
TIA :cheers:
TIA :cheers:
Re: Headers and AC bracket... (Metal_Wulf)
I had to use one of those mounting studs and about 6 washers to get my header down tight and my bracket in the right place.
I used the original stud and a small piece of Stainless pipe about an inch long that slide off the lower part of stud and acted as a spacer. Had to grind and fit a couple of times to get the other bracket bolt holes to wind up in right position ;)
