Ported or manifold distributor vacume
Old 04-24-2011, 01:26 PM
Berniep92
5th Gear
Berniep92's Avatar
Default Ported or manifold distributor vacume
I am in the process of installing a new eddelbrock carberator on my 1975 c3. I am not sure if I am to connect the vacume to the ported or manifold connection on the carberator. I already removed the old carberator. Anyone know what the stock distributor is?
Old 04-24-2011, 02:21 PM
mds3013
mds3013's Avatar
Not sure of the stock source but the best tuners recommend manifold. mike...
Old 04-24-2011, 03:41 PM
69427's Avatar
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Old 04-24-2011, 04:12 PM
daanbc
daanbc's Avatar
St. Jude Donor '12
The vac. source is suppose to be ported if car was equiped with an air pump. But it is better to have it manifold. I will be doing this to mine tuesday. From manifold the car should run a bit cooler and just a tad better on pedal reaction. Ported allowed the air pump to pump air into the exhaust to make it burn more completly. This in turn caused the motor to heat up more.
Old 04-24-2011, 06:36 PM
Faster Rat
Faster Rat's Avatar
With a ported vacuum source you should have no distributor vacuum advance at idle, only as you begin to come off idle. This was done for emissions. Everyone says these cars will idle better, not stumble and run cooler on full manifold vacuum. I'm getting ready to switch mine...as soon as I find a decent tee fitting for my intake manifold.
Old 04-24-2011, 07:31 PM
Paul L
Paul L's Avatar
Take manifold vacuum off the carb. Usually the port under the choke. Use a vacuum gauge to check it at idle.
Old 04-24-2011, 08:55 PM
73, Dark Blue 454
73, Dark Blue 454's Avatar
I agree with everything above. Yes the photo above shows the best source for manifold vacuum on Q-Jet equipped cars.
There are several good reasons to run manifold vacuum; cooler running engine in stop-&-go traffic is a good one,..better off-idle performance is another.
Paul74,..do you struggle with inconsistent choke settings (choke valve opening too slowly) and fast-idle settings? If so, I have a fix. See that thin wire spring behind the pull-off diaphragm? Remove it. With a pair of needle nose, simply grab an end of the spring then pull and it will unravel. That spring fights the divorced choke thermal spring (attached to the intake). If your choke works fine, leave it.
Old 04-24-2011, 09:14 PM
drwet
drwet's Avatar
Use manifold vacuum. I have tried connecting to ported vacuum but it results in a major bog when the vacuum advances the timing just off idle. Doesn't work at all well.
Old 04-24-2011, 10:14 PM
daanbc
daanbc's Avatar
St. Jude Donor '12
[QUOTE=paul 74;1577432816]Take manifold vacuum off the carb. Usually the port under the choke. Use a vacuum gauge to check it at idle.
Originally Posted by pws69
My point is that MANIFOLD VACUUM and PORTED VACUUM come from the SAME SOURCE - and that is the MANIFOLD and it is BELOW the throttle plates - NOT above the throttle plates. - but the actual channel routes BELOW the throttle plates - with a "valve" if you will, that opens immediately "off idle".
Reply from Lars back in 2006.
That's not correct. Ported vacuum is pulled from a hole located just above the throttle plate when the throttle is closed - flip any carb with ported vacuum upside-down, and you can see the ported vacuum hole drilled in the throttle bore just above the throttle plate. The ported vacuum hole is not exposed to manifold vacuum when the throttle is closed. As the throttle is opened, the ported vacuum hole is exposed to manifold vacuum - the throttle plate itself acts as the switch - there is no separate "switch."
Old 04-25-2011, 12:40 AM
73, Dark Blue 454
[QUOTE=daanbc;1577434460]
Not sure what Lars is referring to above.
Yes, vacuum pulled from below the throttle blades is manifold vacuum, and ported vacuum is sourced from above.
The port (tube) shown above doesn't penetrate straight into the venturi. There's a passage to a source below the TB's in the throttle plate.
You can use a vacuum gauge to confirm the above.
There is another source for vacuum on the front of the q-jet toward the driver's side. This is the usual source for ported vacuum. Block that one and use the manifold source.
Old 04-25-2011, 01:07 AM
daanbc
daanbc's Avatar
St. Jude Donor '12
[QUOTE=73, Dark Blue 454;1577435600]
The port (tube) shown doesn't penetrate straight into the venturi. There's a passage to a source below the TB's in the throttle plate.
Thats what he is refering about, and what I was talking about. Some folks look at that port and think it is manifold vac. when in reality that one in the front is ported.
Old 04-25-2011, 06:38 AM
red99bird
red99bird's Avatar
Default Which side
What side of the carburator is the manifold vacume on ???
Old 04-25-2011, 07:36 AM
Paul L
Paul L's Avatar
Thanks for the tip but actually my choke works very well. Temps here until yesterday were about 40*F during the day when I did my spring chores. One punch of the accelerator to the floor, turn the key, and we have ignition. I have fast idle at ~1200rpm and it settles down on warm-up to ~650-700rpm in P or N and ~550rpm in D. Never stalls.
To bring up an old subject, off-idle stumble mentioned above, I have a Viton accelerator pump not subject to ethanol or gasoline additive rot. This matter was studied at length by Lars and Cliff Ruggles about a year ago. The old-style rubber accelerator pump diaphragms do not last long with the gasolines of today. Sometimes ported vacuum gets the blame when in fact it can be just one factor of several.
http://forums.corvetteforum.com/c3-t...t-quality.html
Old 04-25-2011, 07:38 AM
Paul L
Paul L's Avatar
Here is another pic. For reference that is a #7044206 Q-Jet on a #340261 intake, correct for a 1974 L-48 with TH400. The paint is POR-15 engine black (my NOM engine is black).
Old 04-25-2011, 10:28 AM
Birdman
Birdman's Avatar
I'm using the ported vacuum source designated on my Holly Road Demon..in the manual it said hook up a vacuum distributor advance to that port, so I did. Should I switch to manifold?
Old 04-25-2011, 12:10 PM
TheSkunkWorks
TheSkunkWorks's Avatar
Location: Graceland in a Not Correctly Restored Stingray
Ported may be specified, but manifold often yields better performance results. Again, to the timing sticky...
http://forums.corvetteforum.com/c3-t...long-post.html
...tho you'll need to navigate back to the OP.
Old 04-25-2011, 04:35 PM
73, Dark Blue 454
That's odd. Perhaps this is an emissions legal carb?
Get your vacuum gauge and find a manifold source and plug the ported source. Your curb idle will double so adjust it at the carb. You'll enjoy better idle quality and better off-idle performance.
To Ported or manifold distributor vacume
Old 04-25-2011, 06:07 PM
Birdman
Birdman's Avatar
Hmmm, I think I'll try it. I'm also guessing that I'll have to re-time the engine after that? Right now I get the feeling that my vacuum advance canister isn't doing anything. The manual that came with it said to unscrew the internal regulator all the way out for most applications, unless you get spark knock and then to screw it in 2 turns..
Old 04-25-2011, 06:36 PM
Birdman
Birdman's Avatar
From Summit's HEI manual:
11. Connect the vacuum hose to the vacuum advance canister. The vacuum line for
the vacuum advance should be connected to a ported/timed vacuum source. To
properly identify this port, you will need to have a vacuum gauge in hand and test
any small (3/16) vacuum ports on the carburetor. The port that does not have
vacuum at idle is the ported/timed source and is the correct port for the advance
of the distributor to be connected to.
When I rev the engine, it doesn't seem to make any audible or noticeable difference if the vacuum line is connected or disconnected...does this sound right?
Old 04-25-2011, 09:36 PM
SH-60B
SH-60B's Avatar
Put a timing light on it and you'll see a difference, unless the cannister has a leak and isn't functioning.
Quick Reply: Ported or manifold distributor vacume
