Figuring Intake Valve Closing Point for Cam selection and DCR calculation.
Here are some handy calculators. The first one is to calculate the cam angle (that we are talking about) and the second one is to calculate the DCR:
http://www.wallaceracing.com/cam-deg-calc.php
http://www.wallaceracing.com/dynamic-cr.php
For figuring DCR I use The KB silvolite DCR calculator
http://www.kb-silvolite.com/calc.php?action=comp
but for the last entry I input the actual intake closing point I have calculated instead of Intake Closing Point (degrees)ABDC @ 0.050 lift plus 15 degrees
That is not an accurate way to figure actual intake closing point due to the variation in ramp rates.
Mako, I found my cam card. -5 cc pistons .015 piston to deck. .021 cometic gasket 4.060 64 cc heads 4.030X3.750
.036 Quench and thermal ceramic coated piston tops and moly sides
CC billet non sleeved SR
.050 236/244 112
.006 286/294
Valve event numbers Intake 11, 45 Ex 59, 5
.050 236/244 112
.006 286/294
.050 236/244 112
.006 286/294
.050 236/244 112
.006 286/294
Your DCR is too high to run pump fuel normally. BUT your .036 quench, the thermal coatings, 4.11 and manual trans save you. Likely have a good cooling system as well. You could very well see some ping with your gearing now you didn't see with the 4.11. Your on the edge! Always.
Figure 11.24 to 1 and DCR is 8.81 to 1. Using my formula to calculate your actual intake closing point.
I actually ran and still have a 192 T-stat high flow in it with some 1/8th inch holes drilled around it. Stewart pump, big BeKool aluminum rad. and dual spals
DCR is a constant. It is designed into the build and does not change. It is based on intake closing point, static compression and to a lesser degree rod length.
The actual cylinder pressure while the motor is running is nearly impossible to calculate. Maybe someone in here has a PhD in Thermodynamics can do it. But it is beyond my abilities that is for sure.
Starting to read way more then i have in the past on head porting never done it before will be buying vizards book on it. Will someone that has ported heads for yrs maybe even has his own business doing it learn anything from reading not even a chance, im sure i will.
I don';t know what its going to cost but will have the head flowed before i start and after i'm done.
Easy to see how afr is getting there flow numbers over as cast heads, along with the smaller dia. valve stem helping a tad bit to.
FWIW, I do happen to subscribe to the school of thought that theoretical DCR (or what I prefer to call tDCR), as based on the intake valve closing event, is a calculation worthy of consideration when designing many a pump gas, street performance build.
That said, IMCO it's also worth noting that actual DCR in an operating engine varies relative to volumetric efficiency (VE%), thus putting the dynamic in DCR. And, higher VE% engines necessarily produce higher cylinder pressures, which is the real concern here. Thus, I'd caution against making the blanket assumption that any possible combination which mathematically results in a "safe" tDCR will always turn out to be so in practice. It may not be a perfect rule of thumb, but in general I'd suggest that tDCR info be given less weight the larger is the difference between tDCR and SCR for the build in question. My $.02
#33
#34
Understood, and good info for those who need help accomplishing the maths correctly.
It was only after following along for a bit that I felt it probably a good idea to point out for those who might not know otherwise that, yes, there are certain known limitations to the data's applicability; as I imagine certain follow-on questions likely have some viewers scratching their heads.
