Stumbles bad at 4000rpm
Tried to have my 75 Dyno Tuned
The guy made a list of MSD pieces he wanted me to get.
List came to $600.00. He claimed HEI's were worthless.
I replaced my HEI with a known good spare, one with the Pertronix pieces. The Kit was $125.00. It ran a little smoother but stumbles bad at 4000rpm, replaced the plug wires, no difference.
The graph had large Horizontal lines in it.
Still pushed out about 240hp at 5000rpm, Cam good to 5500rpm. There was no valve float, I Have ZZ4 heads on it.
He said my Edelbrock 750 was a little lean in the middle but good on both ends.
Any guesses? I'd like to try to fix it before I bring it if possible.
Ralph
Ralph
Can someone throw me a bone on this one?
Good spark delivery
Carb. working okay
Stupid thing really stumbles at 4000rpm
Son-in Law thinking maybe cam is going flat.
Engine has less than 4000 miles on it.
Ralph
Good spark delivery
Carb. working okay
Ralph
If the cam is going flat you should see grit in the filter.
The HEI that worked OK in your motor home might not be up to the task on dyno tune. How often did you run the motor home at WOT 5500rpm? My favorite on something like this is the performance distributers(edit; Davis ignition) cap, coil, controller. be sure the vac and mech advance is working with about 34* total in at about 3300 rpm. And a good set of plugs. While the plugs are out do a compression check or better yet a leakdown test.
good luck.
good luck.
Location: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
List came to $600.00. He claimed HEI's were worthless. Is this someone you feel is actually technically competent enough that you want to send money his direction?I replaced my HEI with a known good spare, one with the Pertronix pieces. The Kit was $125.00. It ran a little smoother but stumbles bad at 4000rpm, replaced the plug wires, no difference. Question: Does this stumble happen with both distributors, or just the spare unit?
Ralph
Ralph
Just curious, what are your plug gaps, and what was the a/f ratio at the "middle" RPM?
Ralph,
Don't know if this will be of help but had similar experience last summer with my 69 L46 350. Would hit 4000 rpm and it would stumble. Changed, plugs, cap, rotor, wires, etc. etc. The problem ended up being the fuel pump. Now runs flawless.
Good luck,
Norm
Good luck,
Norm
Ralph
I'm still trying to get the dyno read out from the shop.
Actually what I need is a .sfd viewer.
I've looked for an hour and made several calls.
If it's the sock I could back flush the line to clear the screen.
That would work long enough for a test run.
63mako: "Did you see a rise in A/F ratio (lean)in that range on the dyno?"
I believe it was lean lower than than but improved. But I just don't remember the numbers.
I should of taken a picture of the screen.
Ralph
Ralph
Had the same problem old fuel pump.Fuel supply was fine at idle but as the car reved up at speed it would miss and stumble.The pump seals were shot.
I installed an inline fuel pressure gauge today.
The thing pulsed wildly between 6 an zero psi.
Pinching the line it looks like 2 1/2 to 3lbs at 700 rpm.
revving it up did not stabilize the gauge at all.
With that kind of movement the fuel filter, right in front of the gauge, probally isn't plugged.
I have not backed flushed the screen in the tank yet.
Perhaps tomorrow.
Ralph
Perhaps tomorrow.
Ralph
Perhaps tomorrow.
Ralph
Perhaps tomorrow.
Ralph
Perhaps tomorrow.
Ralph
Perhaps tomorrow.
Ralph
The pressure is too low and the pump probably needs attention.
I also had this problem except for me it was at the big end of the 1/4. I put a gauge on the line and only had ~3# of pressure. Replacing the pump totally cured the problem.
You stated that the engine had a problem at 4K RPM, but indicated that it pulled OK further up in the band. A bad fuel pump could cause starvation at 4K, but the starvation should continue from there up. (There may be hp lurking in the higher RPM band that you have been missing out on.)
Either way, 3# is not enough and it would probably be even less under a real load (i.e., not just winging the engine).
Ralph
Ralph
Keep the shiny side up!
Scott
Tell me about it.
It took them 3 days to email me the results and they could not for some reason send me the viewer so I could look at them.
I called and spoke with his supervisor so now he's really mad at me.
But I still can not view the results.
There is a place in Fairfield, Ca. They are reasonably close4, EQ Tuning. Perhaps they will be able to help.
Ralph
Ralph
A factory type pump will give you plenty of fuel delivery. Let the FI guys have the electrics. They require a regulator, bypass plumbing, wiring and are putting out way more pressure than you need. Check for a soft, collapsing hose from the fuel tank to steel line or steel line into the pump. It is that, fuel pump or tank sock.
Electric pumps are a PITA and expense you don't need...and it's absolutely, positively not a "fix" for the problem you're experiencing.
