Steering Wheel off Center - not alignment
73 Vert,
Just (nearly) finished the assembly of a frame off. All is well, except the steering wheel is off to the right about 45 degrees - car goes straight (it's not "alignment").
I apparently assembled something back together incorrectly. As I recall, the steering wheel and assembly (tilt/tele) only goes on one way..
Thoughts?
thanks
Thoughts?
thanks
Did you have steering box arm off the steering box? I did. And when I put the new box on I installed it in the wrong position. It was off a quarter turn.
Yeah, Pitman arm... Couldn't remember the name just then!! I also thought it went on one way, as I put a Flaming River U-joint steering coupler on, instead of the rag-joint. Took everything apart, re-installed, and it came out correct. I changed from power steering, to manual, and the pitman arm is different, hence the change.
Why do you state that "it's not the alignment"? If the steering box is centered, and the steering column is aligned properly with it when you installed the U-joint, and the steering wheel is properly aligned with the index mark on the shaft, then the alignment MUST be off. All it takes to get it properly aligned is some (toe) adjustments to the steering rods.
This paper has all you will ever want to know about C2/C3 Corvette steering system centering procedures.
http://jimshea.corvettefaq.com/wp-co...v28jl20091.pdf
Jim
Jim
