brake fluid
DOT 3 and DOT 4 are basically the same and both will work. They are also compatible with each other. DOT 4 has a little higher boiling point so is better, but DOT 3 will work fine. The only brake fluid you can't use is DOT 5 as it is silicone and is not compatible with your DOT 3/4.
