Will a Small Block Fuel Pump fit a Big Block?
My Fuel pump on my 350 is in excellent shape. The flange looks like it's the same size, is there a huge difference between a small block and big block fuel pump? I'm not getting cheap here, I'd just hate to buy something if I didn't have to.
Re: Will a Small Block Fuel Pump fit a Big Block? (Steve Straus)
The pump will fit and it may work OK on the street, but I wouldn't use it. I ran mechanical fuel pumps in the "old" days on my 427 circle track car. One time after putting on a new fuel pump, the engine would starve for fuel at WOT with a single 850 holley. I found out I had put a SB pump by mistake, I replaced it with a BB one and the problem went away. I've talked to other racers since then that had the same problem.
Hope this helps,
75rat
Re: Will a Small Block Fuel Pump fit a Big Block? (75rat)
I put a new pump on my engine last year The box had a warning notice in it that said for use on Big Block Chevrolet engines only. I didn't have a small block pump to compare though. :confused:
Re: Will a Small Block Fuel Pump fit a Big Block? (silvervetteman)
Thanks guys. From the description it sounds like the pumps have the same physical dimensions but run at different pressures.
big, bigblock, block, blockbig, corvette, difference, differences, filter, fit, fuel, fuelpump, mechanical, pump, pumps, small, smallblock
