91 Camaro Z/28 V8 T5
Old 07-19-2011, 10:08 PM
sakins.02vert
Support Corvetteforum!
sakins.02vert's Avatar
Default 91 Camaro Z/28 V8 T5
I'm thinking about buying a t5 from a 91 Camaro Z/28. This is from a v8, 13-52-066-936 R3 which I believe is a world class. It comes with the Camaro bellhousing which is at a tilt.
Has anyone done this with their c3? I'm wondering how it's going to fit and what fabrication I may need.
I'm also wondering if I'm better off using a GM bellhousing like the one that came with the vettes with Muncie 4 speed transmissions. How does that change things? make them easier?
Old 07-19-2011, 10:19 PM
sakins.02vert
One other thing. Can someone tell me how to confirm that this was from a v8 and not just put behind a V8 by someone else. I.E. really originally from a v6?
I was looking at: http://www.britishv8.org/Articles/Bo...T5-ID-Tags.htm
But there is a question mark there.
Please help. I want to make sure this was a v8 WC T5
Old 07-20-2011, 09:56 PM
stpman
stpman's Avatar
What engine is it bolted to? if I remeber correct the T5 was only offered with the 5.0l not available with the 5.7l
Old 07-21-2011, 07:09 AM
Garys 68
Garys 68's Avatar
26 spline with the shifter in the correct position will be a V8 trans.
WC is indicated by a machined cap on the countershaft hole with printing stamped on it.
Old 07-21-2011, 08:13 AM
tt 383
tt 383's Avatar
Their should also be dog tag, maybe that is what Gary meant? You can then plug the serial number in here from the dog tag. http://www.5speeds.com/t5/
Old 07-21-2011, 01:44 PM
sakins.02vert
Looking at another one. The guys said "its kinda rusty. i will try to get #'s off it.....you can tell by the input shaft. its fine spline. 6 bangers are course".
What does this mean? V8 is fine spline, v6 are course? So is fine 26?
Old 07-21-2011, 06:10 PM
Garys 68
Garys 68's Avatar
V8 are 26 spline, V6 are 14, Fords are 10.
I think some S10s were 26 spline but had a forward shifter location.
Old 07-21-2011, 07:02 PM
sakins.02vert
Thanks Gary
Old 07-23-2011, 12:15 PM
sakins.02vert
So these guys with the t5's are telling me they are 26 spline. So that means these are definitely from a V*. Do I have that right?
Old 07-23-2011, 09:14 PM
sakins.02vert
Sorry I mean v8
Old 08-16-2011, 10:31 PM
sakins.02vert
Update on this.
I'm going to buy a clutch pedal assembly, flywheel, 621 chevy bell housing, etc and a WC T-5 from a Camaro Z/28. So since the Bell Housing is a 621, the trans will be sitting at an angle so I'll need a custom trans mount right? Anyone done this? Any tips? Also, I think my drive shaft is going to need to be shortend because I have a TH400 today. Right?
To 91 Camaro Z/28 V8 T5
Quick Reply: 91 Camaro Z/28 V8 T5
