how to pick a clutch and pressure plate?
I have had this question in my tko install thread for a few days but I don't think many people are seeing it so I want to ask it in this specific thread to read opinions.
I need to buy a new pressure plate and clutch disc. I think the flywheel is going to be saved. Only issues I noticed before I pulled the stuff was
- clutch pedal harder to depress than stock
- clutch pedal vibrated when not depressed, kinda moved up and down very small amount while motor running
- clutch only disengaged the last 1/8" of stroke, pedal had to go to floor in order to shift gears without grinding
I replied to old post. I use the DFX. It has a very light petal pressure. I drilled a hole lower on my Z-bar so it would take less petal travel to disengage the clutch. It's like an inch of movement in - out I set the throw out bearing to like .040 - .060 so it has very little free play. My Sparco racing seat is mounted flat on the floor and all the way against the battery box. So my feet are nearly straight forward. I just operate the gas, brake, & clutch with my feet rocking on my heels.
Flywheels can be resurfaced. Modern clutches are just so easy to operate that I have never felt the need to go hydraulic assisted.
The only thing better than the DFX for holding big power and slicks is going to twin disk setups.
Thanks, man that DFX is expensive.
I just found the flywheel that I just removed. Its a hays 10-130.. 30 lb steel flywheel http://store.prestoliteperformance.c...hevy-1746.html
Damn thats an expensive flywheel! I am researching now what different weights do and if this is the appropriate weight for street use. I thought there would be more interest in this stuff from more people.
Gearing and motor TQ determine what flywheel weight you need. Ya, and what you are trying to do. Clutch kits determine the abuse of what they can handle. good stuff can take on 100,000+ miles if you know how to drive.
I've ripped the springs out of cheap stuff in the past in another one of my cars on a hard launch with wheel hop
I've read your description, looked at your pics. But you didn't exactly say what problems you're trying to correct. So, in these trying economic times, get both the flywheel and pressure plate blanchard ground to remove the cracked/overheated surfaces. Replace the disc, pilot bushing and throwout bearing. Reinstall and happy motoring.
Well the machine shop was giving me crap about my flywheel. They think one or two of the holes were helicoiled before so they sent me somewhere else that was going to re-helicoil the holes, rebalance, and resurface. I didn't want to deal with all that so I ordered a new hays 10-130 30lb steel flywheel, centerforce dual friction pressure plate and clutch, the alignment piece they sell, and a bunch of other stuff I needed. Cost me a chunk of change but oh well.. performance isn't cheap.
I looked around at the aluminum fidenza 15lb and I didn't see any SFI rating and I read something on centerforces website that says do not use the dual friction with any sort of alum flywheel.
contact Tom or his son Adam at Tadco
http://www.straightdrive.com/
equipment from Zoom, former employees and one still is.
funny, a few years back they built a clutch for a gent in Alaska ... for an arctic cat! Tey can & do build clutches for just about anything. Give 'em a call; easy to talk with. They are a real mom & pop shop. Son Adam did work for Petty.
Nope. The setup worked worked great with no chatter and handled the power fine. I did however take the flywheel to a machine shop yesterday that does flywheels all the time as they specialize in automotive parts. He said the holes were never helicoiled and were fine, napa was wrong. So he is resurfacing the old flywheel for me and running a tap thru the holes to make sure they are 100%. The bad part is, I took napa's word and ordered a NEW hays 10-130 sfi approved flywheel that has already shipped. So I am going to sell the used flywheel that is getting resurfaced and will be good as new. Only reason I am selling it is I have a new one coming in that I already paid for and don't want to pay shipping to return it to summit.
I just 'bit the bullet' with my 496 stoker and fitted Centerforce Dual Friction clutch, one of their steel flywheels, new throw-out bearing and center bush in crank. Pedal pressure is less than stock big block clutch.
^ But this is an internally balanced engine.
Nice all the same stuff I've ordered except I didn't go with the centerforce brand flywheel. My throwout bearing was SHOT. Wondering the difference I will feel.
Check-out 'Z' bar linkage and pivot points they can suffer wear.
Yes, I realize it is an internal balance engine.
I thought, perhaps, you had the whole reciprocating assembly...pistons, rods, crank, etc... balanced at a machine shop. Or your new flywheel, like my McLeod Racing billet steel flywheel (and pressure plate), requires machine shop balancing before assembly. Obviously not. Carry on.
