Neutral/Safety Switch....
Old 08-08-2011, 02:23 PM
Richard Cooper
Richard Cooper's Avatar
Default Neutral/Safety Switch....
My neutral safety switch needs to be replaced. I could get it to work by moving the selector up/down in neutral but now nothing works. I am ordering a new switch, but I would like to get the car out of the yard and into the shed until the switch gets here. My question is: there are two plugs on the switch itself. If I remove one of those plugs and put a jumper across the wires would I be able to start the car in either park or neutral according to which plug I used? TIA. I just finished washing the car and its now raining!!!!!
Old 08-08-2011, 02:54 PM
...Roger...
...Roger...'s Avatar
Providing the interrupt isn't effecting your car you can put the 12yellow and 12 purple together to bypass. It will start in all gears.
Old 08-08-2011, 03:10 PM
Richard Cooper
Roger,
Can I find the yellow wire in the plug and jump it to the purple plug? This way I will not have to cut any wires. Thank you very much.
Old 08-08-2011, 03:44 PM
...Roger...
Richard, here is a link to a switch,the switch has 2 purples but if you follow to where the switch plugs in, there should be a yellow and purple in the car harness,jumper the yellow to the purple at this point.
http://www.ecklerscorvette.com/corve...1976-1982.html
Old 08-08-2011, 03:48 PM
Richard Cooper
Roger,
Got it, thank you very much for your help. I just spent about 40 minutes getting the old switch out. What a PIA!!!! Anyway, thanks again and have a great day.
Old 08-08-2011, 03:54 PM
Richard Cooper
Roger,
One more question, as you said there are two purple wires. One of them has a white stripe, which one do I use? TIA.
Old 08-08-2011, 04:14 PM
...Roger...
Do you have a purple/white and purple in the harness coming from the car ?
If so just put a jumper between the 2 , if you have a purple/white and a yellow coming from the car harness just jumper those 2.
Old 08-08-2011, 04:18 PM
...Roger...
Just so we don't screw something up here,tell me what wires you have.
Im hoping from the car you have 12purple/white and 12yellow and then dk blue and lt green.
Old 08-08-2011, 04:20 PM
Richard Cooper
Roger,
I guess getting old also means getting stupid. It was just as you said, the two purple wires were only on the switch itself. The harness from the car had one purple and one yellow.
In May I turned 66 years old and it's been all down hill from there. Thank you again.
Old 08-08-2011, 04:25 PM
...Roger...
No problem Richard , I just turned 58 and I'm feeling it.
To Neutral/Safety Switch....
Quick Reply: Neutral/Safety Switch....
