looking for pictures of stock SBC valve covers with PCV, oil fill cap, breather etc.
I am looking for pictures of the stock SBC valve covers especially for the PCV hose set up, oil fill caps, breather valves, etc. thks bob
Received 2,878 Likes
Hi b7,
Here are a couple of pictures... 71.
Regards,
Alan
Regards,
Alan
that looks great thanks, it looks like on the pass side there is just a 90* elbow that goes into a hose that goes into the bottom or side of the air cleaner? it doesn't really go into the manifold does it? and the drivers side is the PCV tied into a ported port on the carb where does the other end go? thks bob
Received 1,469 Likes
Cruise-In II Veteran
You want a specific model year?
just trying to get ideas for how to change things up on my 355....i have regular style aftermarket aluminum valve covers with a couple of "holes", and i am now using a 79 and later dual snorkle airfilter sitting on top of a Qjet. so i am thinking of going back to an original style set up and ditching the push in breather cap. so I am looking for pictures of the setup so i know what i need to get. thks bob
Hi Bob,
On my 71 q-jet there's only 1 nipple large enough to fit the hose running from the pcv valve. The nipple is actually in the front of the BASE PLATE, not in the body of the carb..
On the right side, in 71, the crankcase breather hose fit's into a pipe in the air-cleaner base.
Regards,
Alan
Regards,
Alan
ok thanks, i appreciate everybodys help. i will look up front there tomorrow and see what there is to see....any body have one of the breather tubes and hoses lying around that they dont need anymore? thks bob
Hi,
Thanks!
If it doesn't make much horsepower it might as well be pretty.
Regards,
Alan
Thanks!
Regards,
Alan
thanks guys, i appreciate the photos and ideas, that gives me a good idea of what i am trying to do, i will go out and look to see what i have, thks bob
ok its changed around, i had to use a push in breather cap with no holes and an integral outlet pipe to connect to the aircleaner housing, so i am still looking for the actual metal tubing and hose that goes from the valve cover to the 79 and later dual snorkle air filter if any body has one they dont need let me know. thks bob
