77 c3 radiator r&r - CorvetteForum - Chevrolet Corvette Forum Discussion
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette
77 c3 radiator r&r
Old 09-13-2011, 08:57 AM   #1
xkeots
CF Senior Member
Default 77 c3 radiator r&r
I changed my water pump but the radiator has a slight leak too. I want to pull it and send it out. (I haven't put the fan on yet) The service manual says nothing about this. Do I have to pull the hood as I am alone here? Please let me know if it is the same as most other GM cars. Pop the top caps and bottom bolts and hoses and out she goes or is there more in a 77 Vette?
I am replacing every old part that can cause a possible breakdown. I am not making a car with all GM parts, sorry, I can't afford it. But all parts that I am using are made in the USA. If the box doesn't say it, I don't buy it.
Jack
77 L82
xkeots is offline   Reply With Quote
Old 09-13-2011, 10:17 AM   #2
Ganey
CF Senior Member
Ganey's Avatar
I pull it by myself w/ hood on. Due to the awkward position strength needed, many would probably prefer 2 guys.
Ganey is offline   Reply With Quote
Old 09-13-2011, 10:29 AM   #3
sstopczy
CF Senior Member
sstopczy's Avatar
I replaced the radiator on my '79 without removing the hood by myself. It wasn't the easiest job, but if you take your time you should be fine. I had read you would need to remove the shroud before you remove the radiator, but while working on mine the radiator came out just fine once I pushed the shroud back toward the engine.
sstopczy is offline   Reply With Quote
Old 09-13-2011, 10:33 AM   #4
bigvette1
CF Senior Member
Default Radiator R and R
Yes, one can do it by themselves, but it is a whole easier and safer to both you and the car finders for two do the job. Hints,
- Hood off, clearance for lifting and getting the radiator to pull straight up
- Remove bolts under fender holding the core support and tilt forward max
- You can pull the radiator with the shroud in, but it is easier to pull both and reinstall both together.
No how you cut it this is a job.
bigvette1 is offline   Reply With Quote
Old 09-13-2011, 05:06 PM   #5
hunt4cleanair
CF Senior Member
hunt4cleanair's Avatar
I'm working through this on my 78, did by myself but agree with bigvette that it would have been easier with two. I pulled the radiator with shroud tilted toward engine but removing the upper bolts on the core support and tilting forward definitely would have helped.
I was pleased by core support had only surface rust so cleaned it up, painted and now working on the engine.
hunt4cleanair is offline   Reply With Quote
Old 09-13-2011, 06:06 PM   #6
Tim H
CF Senior Member
Tim H's Avatar
Quote:
Thats an "oxymoron" statement.
1:Can't afford it,
2:your using only USA parts.
So this means you wont be buying anything at the local parts store and will send off for everything?
Good luck with that.
Tim H is offline   Reply With Quote
Old 09-13-2011, 10:59 PM   #7
xkeots
CF Senior Member
Quote:
1:Can't afford it,
Not really. I get most parts at dealers cost and my parts guy has a lot of old stock there and the old stock was made in the USA.
For example, I just paid $35.00 for a new old stock AC Delco water pump. So I am taking my time. I am sick of doing jobs 2 & 3 times. I say that I can't afford it because I have 10 other cars that I have to maintain too. They all get parts made in the USA. (Except for the Jaguars & Porsches).
So it's not really an oxymoron.
Old 09-13-2011, 11:00 PM   #8
xkeots
CF Senior Member
Thanks for the tips all!
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • 77 c3 radiator r&r
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    correct radiator and shroud? teamo C3 General 2 03-23-2014 01:15 PM
    FS: 77 Rear Suspension and other parts 97C5 C3 Parts for Sale/Wanted 0 03-21-2011 05:25 PM
    cam swap on 77 in car? vetteonbeach C3 Tech/Performance 4 07-11-2010 12:52 AM
    Correct radiator for 1971 LS5 AC MT 71LS5 C3 General 13 10-25-2006 10:06 AM
    Jacking a 77 C3 Joe 77 C3 Tech/Performance 10 05-11-2004 05:48 AM
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
    • Ask a Question
    What's your question?
    Send
