Rocker arm stud bolt broke?
What would cause a rocker arm screw in stud bolt to break? In late
July had a shop install Edelbrock RPM Power Package .Went with Comp Cams 12-660-47 cam. Comp Cam roller tip rockers. Car was idling poorly checked a few things and decided to pull the valve cover. What I found was the broken stud.....
If they added some stiffer valve springs but didn't replace the [40 year old] rocker studs, that might be one reason. If that's the case, you can put a new stud in to replace the broken one...but that probably won't be the last stud that breaks.
poor valve train geometry......maybe the pushrod was too long or too short when you get the stud replaced be sure to check alignment. the blue thing slips over the stud and should touch both valve and pushrod at the same time....and you adjust the push rod length if necessary by getting different length pushrods
I did get +1.00 on the push rods...per Edelbrock. What is the blue thing called I will pick one up...thanks to all found it proform makes one......
Related to Bob's comment on valve train geometry is the length of the slot in the rocker. Look at the rocker (from the broken stud) for evidence that the rocker is bottoming on the stud when the valve is at fully open or fully closed.
Back in the day before everyone began to run full roller rockers, when swapping a higher lift cam into a SBC or SBF engine with stock rockers it was not unusual to encounter this problem. What we discovered was that the variance on the slots in the factory stamped steel rockers could be as much as 30 degrees (from the longest to the shortest slot). You could either enlarge the slot (picking the longest slot and matching the rest to it was always safe) or step up to full roller rockers.
Good luck... GUSTO
Good luck... GUSTO
Gusto14 brought back some memories. We used to have to lengthen the slot so there was room for the higher lift cams. Check if you have some half moon looking marks on the rest of your studs.
I had two break on a pair of Trick Flows. Replaced those and never had any more troubles. Bad out of the box was my diagnosis.
Still have a few replacements - 7/16 bottom / 3/8" top if you need 'em.
Thanks, L88Plus ...spoke with Edelbrock and they are sending a pack of 2.
Just a word about studs....
I bought a brand new set and one broke like yours. Called AFR and they admitted they had a bad material batch made (not sure if they were ARP) but sold them anyway. They replaced my whole set for free...
but you never know so just keep an eye out and if another stud breaks you know it's bad material.
Received 4,583 Likes
C1 of Year Finalist (appearance mods) 2019
This! Metal fatigue is hard to diagnose. You never know when a part is going to fail with time. Do the one side at least since you have it open. Loctite on the threads.
Received 1,875 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
How many threads were engaged in the adjuster? Got any pics?
JIM
JIM
You want the rocker to operate down in the shank area of the stud and the adjuster to grab as many threads as possible. If it's really taking those .100" long pushrods to get geometry correct (need to actually ck and measure) then likely you need longer studs also. Only using a few threads is a recipe for failure.
JIM
JIM
