1971 LT-1 Cam Specs? - CorvetteForum - Chevrolet Corvette Forum Discussion
C3 Tech/Performance
V8 Technical Info, Internal Engine, External Engine, Basic Tech and Maintenance for the C3 Corvette
Old 09-19-2011, 12:05 AM   #1
spdrcr29
CF Senior Member
spdrcr29's Avatar
Default 1971 LT-1 Cam Specs?
Anyone know the specs (Lift, duration, etc.) for an original 71 LT-1 Camshaft?
spdrcr29 is offline   Reply With Quote
Old 09-19-2011, 09:02 AM   #2
Ganey
CF Senior Member
Ganey's Avatar
I 229 E 237 @ .050 .452/.455
Ganey is offline   Reply With Quote
Old 09-19-2011, 09:55 PM   #3
spdrcr29
CF Senior Member
spdrcr29's Avatar
Thank you!
Old 09-19-2011, 10:02 PM   #4
Gordonm
CF Senior Member
Gordonm's Avatar
That may be a modern day replacement cam for the LT1 but the original had way more duration than that. It wa a long duration low lift solid cam. Not really a good cam for modern day engines. It needs a high compression piston and rpm to really work well.
Lookimg arond the duration at .050 is more like 242/252. Those are the numbers that are more like it.
Gordonm is offline   Reply With Quote
Old 09-20-2011, 02:21 PM   #5
Scott Marzahl
CF Senior Member
Scott Marzahl's Avatar
Duration at .050" is 242/254, lift .459"/ .485". To give you an idea of how it compares to a hydraulic cam, doing the math the durations are 231/239. Decent cam for 10.5:1 compression when using the stock exhaust manifolds. If you run headers you can increase your cam selection.
Scott Marzahl is offline   Reply With Quote
Old 09-20-2011, 03:05 PM   #6
Ganey
CF Senior Member
Ganey's Avatar
The cam specs. posted earlier are listed for 3972178.
another source gmpartsdirect
3972178 Mechanical Flat Tappet 70-71
(ID#3972182) duration at .050" tappet lift (intake/exhaust) is 242/254; and maximum lift with 1.5:1 rocker ratio (intake/exhaust) is 435/455. Valve lash is 024/030 and lobe centerline is 116 degrees.
(& in their chart as
I:.E:.455"
E: 435")
Go Back   CorvetteForum - Chevrolet Corvette Forum Discussion >
Reload this Page
  • 1971 LT-1 Cam Specs?
    Related Topics
    Thread Thread Starter Forum Replies Last Post
    Camshaft replace instructions RJW C7 Tech/Performance 2 08-04-2016 12:11 AM
    LT1 Throttle body bolt torque spec? CRUSIN1 C4 Tech/Performance 2 07-18-2015 07:32 PM
    LT1, what are the specs for a set of roller rocker arms do i buy? boonie c4 C4 Tech/Performance 4 03-20-2010 04:30 PM
    LT1 and LT4 cam specs? GRX Engine Mods 3 05-29-2002 11:48 PM
    What are the specs for a stock L98 and LT1 cam? Corey_68 C4 Tech/Performance 7 12-18-2001 08:44 PM
    Tags
    1971, 197171, 1cam, 3972178, arms, cam, camshaft, corvette, lift, lt, lt1, oem, replacement, rocker, specs, stock
    Search this Thread:
    Click for Advanced Search
    Posting Rules
    You may not post new threads
    You may not post replies
    You may not post attachments
    You may not edit your posts
    BB code is On
    Smilies are On
    [IMG] code is On
    HTML code is Off
    Trackbacks are Off
    Pingbacks are Off
    Refbacks are Off
    Forum Jump
    • Ask a Question
    What's your question?
    Send
