How do i know if I have FE7 Gymkhana suspension?
Sorry for the newbie question but I have a 76 L-82 with a TH400. I read "A total of 5,368 Corvettes had the FE7 Gymkhana suspension installed; 5,720 came with the L82 V-8; and 2,088 had the M21 four-speed close ratio manual gearbox. "
How do I know if I have FE7 Gymkhana suspension?
Also, was the stock driveshaft steel?
CorLeb (12-24-2020)
this is what I found
1. Special front springs and shocks
2. Special rear (7 leaf) spring and matching shocks
3. Special front stabilizer bar (1 1/8") with H/D rubber mounting hardware.
4. Special rear stabillizer bar (7/16') with H/D rubber mounting hardware.
Other than steel what do you think a 76 driveshaft would be made of?
Wheelman_99 (07-25-2020)
4alludo (12-27-2020)
Drive shaft is steel.
The rear sway bar is a tricky thing, a 7/16" bar is soooo tiny that on a 35 year old car you may have looked right at it and thought it was some kind of hard line. You wouldn't be the first person to make that mistake.
It will attach to some kick-ups above the spring bolt.
I drove an 82 with the base springs, it felt very smooth going down the road. The 78(originally FE7, now mostly FE7 with a FG rear spring) is not bad, but smooth is not a word I would use to describe it.
Received 1,469 Likes
Cruise-In II Veteran
Optional rear sway bar at t-arm.
For 76, FE7 was available with all power train combinations, including base engine cars.
Purchase the 76 assembly instruction manual (AIM). AIM has diagrams for the optional FE7 installation and will give you something to look for.
You're gonna want the AIM for lots of things.
Caution: If you do not find a factory rear sway bar, it does not necessarily mean your car is/was not FE7 -- only that bar is missing. Do you have any original documentation for your car? Window sticker? Invoice? Build sheet?
The reason the 82 felt "smooth" is because by that year the base springs were so soft that the car is like a marshmellow. The rear composite in 82 is 192 lbs which is pathetically soft. The car was no longer a sportscar by then but just a cruiser. The 225/70/15 tires on the base car didn't help the handling but sure helped the ride!
I was well aware as to why it felt smooth - that's why I mentioned the fact that it was a base car.
If the car feels smooth going down the road, that may be good evidence for it NOT being an FE7 car. FE7 is firm, but not punishing (which is how I'd describe an 84/85 Z51 Corvette, or my 83 F250HD)
The 9-leaf iron springs are right around that rate too.
The 9-leaf iron springs are right around that rate too. I was well aware as to why it felt smooth - that's why I mentioned the fact that it was a base car.
Just checked the MVMA specs for an 81, they do not offer an 9 leaf. There is the composite BASE spring and an 8-leaf spring for FE7. Most likely due to the lighter rear weight of the 80-82 cars.
As to your statement about the spring rates not being close: sadly, the MVMA specs for the 76 are missing the sections on suspension.
75: base spring was 9 leaf, 170 lb/in
77: base spring was 10 leaf, 196lb/in
78: base spring was 10 leaf, 198 lb/in.
80: base spring was 8 leaf, 172 lb/in
81: base spring was composite, 172 lb/in
So I'd have to "go out on a limb" and reaffirm my sentiment that the FG spring is close in rate to the base springs of earlier years. Certainly much closer than the ~300lb/in rate of the FE7 cars.
True, but they may be able to make some judgments based on comparisons we make. Unless of course their suspension is shot... but that's not likely on a 30+ year old car, right?
Reading your original post it looked like you were stating that the FE7 was close to the 192 of the glass spring. Sorry, I was just trying to point out the diff between FE7 and standard.........carry on...:O)
