1978 Rear end ratio
Old 09-25-2011, 10:41 AM
donnie1956
donnie1956's Avatar
Default 1978 Rear end ratio
What is stock rear end gear ratio on a 78? How or where is that info found on the car?
Old 09-25-2011, 01:30 PM
joewill
joewill's Avatar
3.08 or 3.55, don't know which is stock. the data is not found on the car unless you have a tank sheet or documentation somewhere.
get the numbers off the rear carrier and we can tell you what the numbers mean.
Old 09-25-2011, 01:37 PM
Mike Ward
Mike Ward's Avatar
Ratios available were 3.08, 3.36, 3.55 or 3.70 depending on engine, transmission, delivery state and/or altitude (believe it or not)
Old 09-25-2011, 02:02 PM
...Roger...
...Roger...'s Avatar
If your wanting to know whats in your car at present you can find that out by counting the driveshaft revolutions to rear wheel revolutions or you might try recording your RPMs on the highway at certain speeds and posting that here on the forum,someone will have the same speed to rpms. Basically only 4 choices.
To 1978 Rear end ratio
Quick Reply: 1978 Rear end ratio
