carb to intake manifold specs
Old 09-28-2011, 09:08 PM
mattu
mattu's Avatar
Default carb to intake manifold specs
i have a 77 vette with a 350 rochester quadra jet carb. it has a heat insulator gasket under carb...does anybody know the torque specs for the 4 mounting bolts from the carb to the intake manifold?
Old 09-29-2011, 11:06 AM
billla
Support Corvetteforum!
billla's Avatar
St. Jude Donor '14
I didn't see an answer here, so I'll dive in I've never seen a torque value for this - and my service manuals just have "tighten evenly". It's certainly not a torqued fastner, and you don't want to overtighten - but just snug is fine...I guess I would estimate 7-10 lbs-ft if I had to put a number on it...?
Anyone else?
Old 09-29-2011, 11:26 AM
69 Chevy
69 Chevy's Avatar
It's been a long, long time since I fooled with a Q-jet. But as I recall, you can bow the top of the carb if you torque the 4 perimeter mounting bolts too much. I did and ended up sanding it down on a piece of sandpaper on a piece of plate glass to ensure evenness. As far as torque value goes, it doesn't take much to get it to seal on a new gasket so billla's got it about right.
mattu
mattu's Avatar
thanks, last gasket leaked so i think it was overtightened and pushed down on plastic inserts. will try your advice, thanks for diving in!
Old 09-30-2011, 07:42 AM
71scgc
71scgc's Avatar
12 ft-lbs. This from 1971 CSM. IIRC, it also has a tightening order diagram. All this is buried in the carbs section of the CSM.
Old 09-30-2011, 03:31 PM
billla
billla's Avatar
St. Jude Donor '14
Cool - thanks!
Old 10-02-2011, 08:41 PM
LeMans Pete
LeMans Pete's Avatar
St. Jude Donor '13-'14
Follow the diagram. If you went around in a circle, that was probably the source of your leak.
To carb to intake manifold specs
Quick Reply: carb to intake manifold specs
