Where do you get your oil filters?
Old 10-06-2011, 10:59 AM
a1sensei
a1sensei's Avatar
Default Where do you get your oil filters?
I have always bought my filters at Wal-mart because, while I am not a fan of Fram filters, I could get their premium filter for a lot less than a Purolator or Mobil 1 filter at an auto parts store. Today, I went to Wal-mart and they did not have the filter for my '81 except in the Fram economy filter. They no longer stock the premium filter in my size. So I went to Autozone and they also no longer carry the filter in anything except the cheapo. What are you guys doing?
God bless, Sensei
Old 10-06-2011, 11:18 AM
Paul L
Paul L's Avatar
Napa Gold (a WIX product). It is the size of the old PF-35 that I formerly used.
Old 10-06-2011, 11:25 AM
bluthundr
bluthundr's Avatar
Seconded
Old 10-06-2011, 11:26 AM
Jeff_Keryk
Jeff_Keryk's Avatar
Mostly Wix from O'Reilly. I think I pay $6 to $7. Kinda high; they usually give me 10% off if I snivel.
Old 10-06-2011, 11:28 AM
pws69
pws69's Avatar
"Thirded"!!
Old 10-06-2011, 11:45 AM
7T1vette
7T1vette's Avatar
Received 2,713 Likes on 2,271 Posts
NAPA 'Gold' or Wix.
Old 10-06-2011, 11:49 AM
HBZ_81_C3
HBZ_81_C3's Avatar
WIX
Part Number: 51069R
UPC Number: 765809129030
Principal Application: Racing Applications Only
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.330
Outer Diameter Top: 3.600
Outer Diameter Bottom: Closed
Thread Size: 13/16-16
By-Pass Valve Setting-PSI: None
Max Flow Rate: 28 GPM
Gasket Diameters
Number O.D. I.D. Thk.
Attached 3.444 3.100 0.260
Old 10-06-2011, 12:31 PM
a1sensei
a1sensei's Avatar
You guys are the best! Napa is a little out of the way, but they have my filter ($5.04) in stock! And I love Wix filters, I used to use them on my '67 Mustang back in high school.
God bless, Sensei
Old 10-06-2011, 01:06 PM
gcusmano74
gcusmano74's Avatar
If you are running the stock exhaust manifolds, you can fit the medium truck filter. NAPA calls it a 1794, in their Gold Series filter line. It has enough filtering area that your pump will probably never go into a bypass mode, and you will filter 100% of the oil 100% the time. You will get more oil to the bearings at all times, because the pressure drop across the filter is lower than the (much smaller) passenger car filter.
If you are running headers, you will have to check for clearance first. If you have an engine oil cooler, you probably won't be able to use it, it will most likely hang too low.
Old 10-06-2011, 03:08 PM
Paul L
Paul L's Avatar
God bless, Sensei
NAPA is a little out of my way as well but I only do 1,000-1,500 miles each year so that means just one oil change (just done before the coming winter and storage). So I buy three when there and that does me for the same number of years.
Old 10-06-2011, 03:54 PM
billla
Support Corvetteforum!
billla's Avatar
St. Jude Donor '14
Old 10-06-2011, 05:29 PM
texas jim
texas jim's Avatar
F/ sure WIX and NAPA. I bought a starter f/ my '81 'Vette this past year and had a conversation w/ the guys at NAPA about in the '60s and early'70s never hearing of a shim to get the starter to fit properly and spin w/o the crazy "zing" sound of teeth not meshing. This came into play inthe '80s from what I remember. We spoke f/ awhile, and I bought the starter they had in stock, afew dollars more than AutoZone, etc., and went home and installed it, without any shim. I hit the key, and just like cotton on cotton, it spun and started the engine w/o a sound. Beautiful everytime. So it's not just the WIX filters that are better, as I've read in filter reviews where they cut the filters in half and check f/ what's in there to filter your oil and how, it's most all the parts that NAPA carries, that are alittle more expensive, but worth the few extra dollars. Fram is rated one of the worst, even their best filters. 2 guys who have built 455 Olds engines have had engines lock up due to Fram filters. I have a 455 Olds in a '62 Ford pick-up and I frequent the Olds site often. I ran Fram filters all the time years back, but stopped in the last ten years.
Old 10-06-2011, 05:39 PM
Paul L
Paul L's Avatar
The NAPA folks here are "car people". They know the old cars. If they don't have what you need they can get it in 2-3 days, from ANY source. Their knowledge and computer systems can reach far and wide.
FWIW, I don't get involved in the oil threads. They are tedious but just a comment here. I have used Castrol GTX 10W-30 for many years in my Corvettes and for the last the last five or so (a 1967 and a 1974) added the little bottle on the left. Inexpensive insurance. No problems. I do use Mobil-1 in my DD, a modern Impala.
Old 10-06-2011, 06:20 PM
70BBvert
70BBvert's Avatar
Buy most of my parts at NAPA. And if you're a AAA member you get a discount of 7% IIRC, just show your membership card
Jim
Old 10-06-2011, 08:03 PM
3JsVette
3JsVette's Avatar
Received 2,490 Likes on 1,644 Posts
I'm a little surprised to see your local Walmart doesn't have more of a selection. There are no Walmart stores in New York but in near by New Jersey they carry A/C Delco.
Old 10-06-2011, 08:09 PM
Paul L
Paul L's Avatar
But what can you get these days? The original for C3 was PF-25. The larger alternative was PF-35. Then the PF-25 was gone as was the PF-35. The PF-1218 was close to a PF-35 but it is ? replaced by a tiny PF-454. GM/Delco does not take care of older cars. NAPA/WIX does.
Old 10-06-2011, 09:18 PM
iokepakai
iokepakai's Avatar
Default Napa
Went to Napa they gave me this one! I see some of you guys use the same filter.Holds more oil,any other advantages??
[IMG][/IMG]
To Where do you get your oil filters?
Old 10-06-2011, 10:12 PM
C3 4ME
C3 4ME's Avatar
Yup, Napa gold for me too.
Old 10-06-2011, 11:23 PM
7t9l82
7t9l82's Avatar
that's the one i use, the extra capacity is a bonus for keeping the oil cleaner. doesn't dilute with contaminants. as easilydue to volume. anyone know if Hastings and Donaldson still make filters? both were excellent filters.
Old 10-07-2011, 12:15 AM
Oldguard 7
Oldguard 7's Avatar
AC Delco PF454 Advance Auto or WIX (wherever sold)
Quick Reply: Where do you get your oil filters?
