Edelbrock Performer 2101 and qjet choke question
So I took off my stock manifold to get it cleaned up and one of the thermostat housing bolts got stuck and broke off. I've tried drilling it out and I'm not getting anywhere close to getting it out. So that's left me with a problem, I need an intake for my 4MV qjet that's being rebuilt as I type this by SMI.
I've looked at quite a few pictures of the 2101:
and have yet to see one picture of the divorced choke hooked up.
I've seen the 8901 part:
and the 9171 part:
I've read a few places that the 2101 is a drop-in replacement for the stock intake and that "The QuadraJet carburetor bolts directly to the "Performer" utilizing all stock brackets, fittings and cables".
So I'm pretty convinced it's what I'm looking for, just trying to figure out if there's anything else I need to get things hooked up right so I can order them now.
and the 9171 part:
http://www.edelbrock.com/automotive_...ormer-sb.shtml
2104 is FOR 1987-95
CAST IRON CYLINDER HEADS
Choke parts:
#1931 is listed for divorced choke.
#1930 is for later chokes.
2104 is FOR 1987-95
Choke parts:
I installed a 2101 on my 74 many years ago. The choke rod needed to be a shade longer than stock. I used a longer choke rod from my old pickup truck (that was on it's way to the boneyard). I didn't know at the time that Edelbrock sold a longer rod.
After a while, I decided to remove the heat riser, reasoning that the aluminum manifold heats up quicker than an iron one. Also, why install a high flow exhaust system if you are going to have one side valved off half the time? I got a spacer to replace it from one of the repro houses (Zip, maybe, or Mid America). Other than that, no issues.
From my looking around, it seems that the 2101 and 2104 are very similar. The difference the Edelbrock catalog states is that the 2104 is designed for "V8's that have heads with canted center bolt holes" whatever that means.
Mine will be the non-EGR version and I already have a new choke coil and housing from Corvette Central on the the way (was for my stock intake).
So I'm still assuming the 2101 is the correct choice and not the 2104?
carb gasket
Does someone know the correct carb gasket for the qjet/2101 combo? The gasket I pulled off my old intake doesn't look like it would be correct for the Edelbrock.
It's a pretty quick job for a machine shop to drill and helicoil that...
Not all Q-Jets can be converted - which is why I brought this up a couple of times on the other thread
It should be the 2101 - the 2104 is for Fast Burn/Vortec-type heads.
http://www.summitracing.com/search/P...rb+base+gasket
Basically any open, spread-bore gasket will work; see below:
I think my original looked more like this:
Now with the Edel 2101, there's that middle wall in the plenum between the left and right runners if that's the correct terminology. If I used a stock 1/4" gasket, wouldn't the gap between the left and right tunnels cause a problem as air from the left could be sucked over to the right? I read somewhere to use the thinnest gasket you can find which eliminates that center wall gap between the bottom of the carb and intake.
Maybe I'm making something out of nothing. I hate myself as I'm almost to the point of finding another stock intake and just being content with it. I wish I would have taken my intake to a shop with the correct tools to correctly take out my broken bolt, would have saved me and this forum some grief.
I do appreciate all of input though!!! It's a learning curve for me.
The reason I ask these questions about the 2101 is that I find it hard to believe that any aftermarket products just "bolt up" like they say they will without modification. Take this image I found in someone elses thread where they were using a 2701 and the fuel line doesn't match up. I read further in that thread that while the 2101 won't match up 100%, it's only off about a 1/2" and the line can be pretty easily bent to reach it. The SS line I have from my pump to carb is pretty tough to bend but I think I could get a 1/2" of height from it. I just didn't want to end up with my qjet on the 2101 and end up with something that looks like this, thusly causing me more headaches:
Let's back up for a second. I said this on your other thread and elsewhere, but if you decide to go to an aftermarket manifold you shouldn't expect anything to "just bolt up", period. Fuel lines, linkages, vacuum lines - figure everything may need some "tweaking" or even mild fabrication to make it work. The only way to really know is to bolt in the manifold and start working through it all.
Now...two things. First, did you bugger up your old manifold so much you really think it can't be fixed? Because they can helicoil just about anything Second, if you did want an iron manifold, they're a dime a dozen.
As for the "crossover" between plenums with an open gasket, it's not really an issue. It happens to some small extent - but it's not worth worrying about. An old trick to get a few more RPM out of the LT-1-type intake was to cut down the center divider in the middle specifically to allow for this
