Looking for Turbocharged C3 corvettes
C3's were Turbo'd a fair amount in the late 70's and early 80's only problem was that they didn't work all that well cause there wasn't a Computor running the show. Now that every Car sold has a ECM its somewhat easyer to make a Turbo Car work. Gale Banks has re indroduced there Gas Twin setup only now with EFI and the Vintage Air Frontrunner belt. Accell used to sell a Single Turbo kit back in the Day and I'm sure one of those comes up on e-bay every so often. There were a few more as well. Just dump the Blow threw Carb and get EFI involved. Both Single and Twin Turbo Hoods should still be avalable as well. If you can fabricate Headers and or Mainfolds and use one of the Serpintene Belt setups of today You will save enough room under the hood to mount Turbo (s) up forward and high enough that the Oil will drain back to the Pan with out a Pump.
Tumar,
who's carb were you running? Did it have a boost referenced power valve or crutch, or were you just running the heaviest spring possible. (everyone knows that boost pressure in the bowl in actually higher than boost pressure under the carb hence the power valve issues most newbies encounter).
Originally it came from Gale Banks Engineering. Then it went to Turbo Engineering, the Carb Shop and a couple of others I can't remember anymore. Everybody had an idea, everybody had a solution. Engine Dyno's , Chassis Dyno's. Making the Engine Run under Full Throttle wasn't all that hard to do it was making it run around on the street that was difficult. All the wile knowing that if it had a hick up I would Melt a set of Pistons which I never did although I did melt an Exhaust Valve or two. A Carburetor is nothing more than a controlled fuel leak, a blow threw Carb is nothing more than a fuel leak out of control. The best place that Carb ever went was the trash.
I know this thread hasn't been updated in 6 years, but I'm shamelessly adding my car. It's a real driver that occasionally sees the track.
Turbo: Single 88mm.
Engine: 6.0L Forged LS1.
Trans: 4L80E.
Rear: 4 Link with Ford.
Build thread in signature
Turbo: Single 88mm.
Trans: 4L80E.
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,329 Likes
After 9 years and a bunch of removed or branded photos, it’s time for a new thread on the topic.
