Bonding Fender to firewall NOT Plexus MA-550
I had to break the bonds at the rear of my passenger side fender for realignment. The previous owner had reattached it too far out so there was excessive amounts of shims on the upper hinge.
After hours of cleaning and trial fitting I glued it back with Plexus MA-550. It was supposed to be the best thing to use. Problem is it did not get hard. A phone call to the vendors tech line reviled that the cartridge probably got hot in the garage. The tech said to remove all the Plexus material and start over. I asked that since I already spent $86 on the adhesive that is now bad, and must spend hours cleaning up the bad product, could they discount the new tube in anyway. His answer was that he would not discount it in any way since I am a one time user. I guess customer satisfaction does not count if you are not a repeat customer
If the product is that sensitive to heat they should have a warning on it.
Could anyone suggest another product to use as I will never use a Plexus product again
Isn't 3M 8115 THE stuff to use for bonding panel?
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
There are several epoxy glues you can use to do this... I've never heard of Plexus MA-550 but then I don't get out much.
We only use SEM 39747 (about 30 bucks per tube) to glue the panels on and it does take a special gun to apply. But the stuff works and looks factory when dry.
Willcox
Willcox
Wayne,
By asking the date, I am assuming you are familiar with the product?
After using it I have found out that shelf life is critical factor (one year max) and it is very easily damaged by heat (normal summertime garage temp will damage it)
I sticker on the tube that said 'do not store in at temps over 90deg and check self life before use' would have been very helpful.
The tech rep said that they store the product in a climate controlled area! If I had know this I would have put it in my sock drawer after buying it for close to $90.
The part that bothered me most was when he referred to me as a 'one time buyer' so discounting a replacement was not possible. Not even a sorry our product failure is going to cause more work on your part.
SEM 39747 is what I will use after I get this mess cleaned off.
Tom
Tom
Never heard of Plexus MA-550 .
I used 3m#8219 adhesive, to attach my front clip.
work time 30 minutes, - cures 24 hours, sets up rock hard.
you have to work fast 30 minutes get everything into place.
pretty sure 3m stands behind all their products. !
If your dates are correct, that is your problem, and the company needs to stand up and do the right thing. Any epoxy product that is 17 months old is subject to be bad. Shelf life is typically much less than that. At the very least they should replace the product.
Wayne,
Tom
Tom
The funny part is I am not a one time user. I own a sign shop and use lots of 3M DP8010. I was talked into trying the Plexus MA-550. Not wanting to test it on a customers job that I would not see again, I tested it on my own car. Nexet time I use a new product I will test is on scrap and put it under the bench. That will save all the time removing a product that did not work.
Header Bar on 74 vette
Willcox
Willcox
I realise this post is now 6 or so years old, however I have to replace the header bar on my 74 vette. The old one has rusted out.
Would you still recommend the SEM 39747, or is there something better on the market now?
Cheers
Greg
Maybe start a new thread with the Willcox name in it to get their attention? You could also send off an email, they are very helpful and easy to deal with.
