LS3 in 69
Old 11-28-2011, 02:43 PM
BB502
BB502's Avatar
Default LS3 in 69
Hi
Will GMPP ECU wiring kit work with a used Corvette LS3 or does it only work with GMPP crate LS3 ?
//Peter
Old 11-28-2011, 05:44 PM
Garys 68
Garys 68's Avatar
The wiring should work, but are you considering the GMPP package with harness, pedal, ecu?
If so, check over on LS1tech conversion board, it seems the GMPP ecu is locked and not the best choice for any mods.
It might be cheaper to modify an existing harness and have the ecu reprogrammed.
Old 11-28-2011, 07:34 PM
Gordonm
Gordonm's Avatar
I am putting a LS3 in my 72 and used a custom harness from PSI. Not in yet but the harness is top notch and I am using the LS3 computer that has been reprogrammed. Cost was not that bad either.
Old 02-10-2013, 12:51 AM
sparky58
4th Gear
sparky58's Avatar
Can you share info with me about your motor change out? I have a 69 thinking to do the same.
Old 02-10-2013, 01:29 AM
MrJlr
MrJlr's Avatar
I love ls swaps!!!!! Maybe me someday if I have the *****!!!!
Old 02-10-2013, 05:53 AM
Gordonm
Gordonm's Avatar
Here you go. All the info I have so far. My project is stalled right now due to personal issues but it is running
http://forums.corvetteforum.com/c3-t...o-my-72-a.html
To LS3 in 69
Quick Reply: LS3 in 69
