hydroboost
Old 12-04-2011, 10:23 PM
TOM B1
TOM B1's Avatar
Default hydroboost
I have a 69 vette and am installing a hydroboost unit.
Where are you guys getting the adapter plate from.
the plate that adapts the unit to the firewall.
Old 12-04-2011, 10:35 PM
MalibuVLX
MalibuVLX's Avatar
Default hydroboost firewall mount
Here is one place. I made my own, but this looks like it would work well.
http://store.corvettengineering.com/...b8dba5ec8743e1
Old 12-04-2011, 10:49 PM
TOM B1
TOM B1's Avatar
I thought they had to be about a 1/2 inch thick plate
Old 12-04-2011, 11:05 PM
DRIVESHAFT
DRIVESHAFT's Avatar
It depends on the way you install it.
The mounting plate that I am using is a stock Astro Van mounting plate, and is only about 1/8" thick.
Old 12-05-2011, 07:18 AM
MalibuVLX
MalibuVLX's Avatar
Some use the mounting plate as the spacer so the accuator rod to the brake pedal lines up. Others, and myself, make the rod adjustable or get the correct length. So as long as the plate is strong enough to support the weight of the booster and M/C, thickness does not matter. The one you may see on here that is 1/2" thick, the guys son is a machinist and custom made that out of alum. Mine is made out of 3/8 plate, becasue that is what I had.
Old 12-05-2011, 08:56 PM
MN80Vette
MN80Vette's Avatar
Our CNC machinist son made me one:
I'm sure he saved the program, so he could probably make another one.
To hydroboost
Quick Reply: hydroboost
