Do 68-77 T-Tops fit 78-82's??
Old 01-28-2011, 02:25 PM
jayfire
jayfire's Avatar
Default Do 68-77 T-Tops fit 78-82's??
I got a pair of t-tops off of craigslist from a guy parting out a 79 corvette. They came with the inner pads as well. After getting them home, they do not look like the ones I have on my 79. They look like they fit the 68-77's. Would they fit a 79? With what mods? Thanks
jayfire is offline
Old 01-28-2011, 03:33 PM
Easy Mike
Support Corvetteforum!
Easy Mike's Avatar
Received 1,469 Likes on 1,248 Posts
Cruise-In II Veteran
78-82 tops have only one latch. 68-77 tops have two latches.
You can use the earlier tops on a later car if you change the halo panel hardware to the earlier style using the triangle mounting bolt.
Easy Mike is offline
Old 01-28-2011, 03:48 PM
jayfire
jayfire's Avatar
What is the halo panel hardware and triangle mounting bolt? Any pics or part numbers of what I would need to fit the early tops to a later car? Is there any hardware I could use from the 79 tops I already have? Sorry for the newbie questions.
jayfire is offline
Old 01-28-2011, 11:33 PM
jayfire
jayfire's Avatar
ttt
jayfire is offline
Old 01-29-2011, 11:13 AM
Oldguard 7
Oldguard 7's Avatar
Really? One latch? I thought there is one for each top. I may be missing something in my thinking. Explain please.
Oldguard 7 is offline
Old 01-29-2011, 12:06 PM
Easy Mike
Easy Mike's Avatar
Originally Posted by jayfire
...What is the halo panel hardware and triangle mounting bolt?...
Check the aftermarket provider on-line catalogues. 78-82 cars use these receivers.
Earlier cars use the tirangle bolts.
...Any pics or part numbers of what I would need to fit the early tops to a later car?...
Purchase the AIM for any of the earlier years and use the t-top part numbers.
...Is there any hardware I could use from the 79 tops I already have?...
No, other than the shims
68-77 tops have front and rear latches. 78-82 tops have a front latch, but no rear. They use a bullet nose connector at the halo panel and the hardware in the pic above. Electrical connector is for the theft alarm.
Old 01-29-2011, 01:13 PM
Oldguard 7
Oldguard 7's Avatar
Ding ding ding ding ding ding ding........ The light bulb finally came on. I'm not the sharpest knife in the drawer
Old 01-29-2011, 08:21 PM
jayfire
jayfire's Avatar
OK, if I change out the rear plate and use the triangle bolts, how does it hold the rear part of the t top down? Do you still use the rear latch? If so, what does the rear latch attach to? This is becoming a PIA!!!
jayfire is offline
Old 01-30-2011, 05:20 PM
hunt4cleanair
hunt4cleanair's Avatar
During my morning run through the golf course, saw a 77 coupe, very nice with glass t-tops that had to be post mid-78. The front tag had a "Sheriff Assocation" license plate but still walked over to take a peek. A very nice 77 that looked sharp with those glass t-tops. he made it work
hunt4cleanair is offline
Old 01-30-2011, 06:15 PM
jayfire
jayfire's Avatar
I'm just stumped on how the rear part of the t top stays tight. Anyone have pics of their 68-77 t tops and how they attach in the rear. Thanks
jayfire is offline
Old 01-31-2011, 11:57 AM
jayfire
jayfire's Avatar
ttt
jayfire is offline
Old 03-15-2022, 09:30 PM
JayBurnt77
Cruising
JayBurnt77's Avatar
this is a weird post, check my name and check that guys,
Lots of great info, Im also after a 77 t-top panel from ebay, used from 60~70 era.
JayBurnt77 is offline
Old 03-16-2022, 02:51 PM
Tranz Zam
Tranz Zam's Avatar
They pretty much attach the same way the front latch does. The latch assembly front and rear look the same. I can get a pic later on.
Tranz Zam is offline
Old 03-16-2022, 03:07 PM
JayBurnt77
Cruising
JayBurnt77's Avatar
But say you have a 77 Top and the pads got burnt, you nee a 77 pad only?
Old 03-17-2022, 11:02 AM
vettebuyer6369
vettebuyer6369's Avatar
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,331 Likes on 2,775 Posts
You are responding to a post from 2011.
vettebuyer6369 is offline
To Do 68-77 T-Tops fit 78-82's??
Quick Reply: Do 68-77 T-Tops fit 78-82's??
