1978 corvette L-82
If thecar won't idle, my first thought is vacuum leak. there are a lot ov vacuum lines on a C3, look for cracked, broken or disconnected lines.
I'd start with capping all the connections at the carburetor, and reattaching them while monitoring a tach. You could have more than one.
Loosen the nuts/bolts holding the carb to the intake. Wiggle the carb around to find where the studs/bolts are best centered in the mounting holes, then hold the carb there while you snug down the bolts/nuts. DO NOT overtorque the mounting fasteners.
I think the primary throttle plates may have been interfering with the intake manifold and that would not allow the plates to fully close.
